09-04-2011 11:23 PM - edited 03-07-2019 02:02 AM
I think I might have a problem with how my network is set up. Cable Modem --->ASA5505--->Cisco 3660--->Switch For some reason if I use the ASA as a DHCP server too, the internet is much faster. Could the 3660 be slowing down the netwok? The 3660 has 2 FE ports, so it should be running good at 10/100 correct? Is there another setup I should consider to help speed up the network? I also have a Cisco 2600 with dual enthernet ports, could I use that as well to help take some of the preasure off the other devices?
Below are the running config for the 3660 and the ASA
Cisco 3660
Building configuration...
Current configuration : 1103 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.1 192.168.1.19
ip dhcp pool 192.168.1.0/24
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 8.8.8.8 8.8.4.4 192.168.1.14 192.168.1.13
username woodjl privilege 15 secret 5 $1$FJyW$Ozgsn9oO0acvYSSeohvzX/
interface FastEthernet0/0
ip address 192.168.2.2 255.255.255.0
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
ip nat inside
duplex auto
speed auto
ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 600 life 86400 requests 10000
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.2.1
control-plane
line con 0
line aux 0
line vty 0 4
login
end
ASA5505
ASA Version 8.2(3)
hostname ciscoasa
enable password DQucN59Njn0OjpJL encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address 192.168.2.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address dhcp setroute
interface Vlan5
no nameif
security-level 50
no ip address
ftp mode passive
access-list outside_access_in extended permit icmp any any echo-reply
pager lines 24
logging enable
logging monitor emergencies
logging history emergencies
logging asdm emergencies
logging mail emergencies
logging class auth history emergencies monitor emergencies mail emergencies asdm emergencies
mtu outside 1500
mtu inside 1500
icmp unreachable rate-limit 1 burst-size 1
icmp permit any outside
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
access-group outside_access_in in interface outside
route inside 192.168.1.0 255.255.255.0 192.168.2.2 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.2.0 255.255.255.0 inside
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.2.5-192.168.2.36 inside
dhcpd dns 68.87.68.166 interface inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum client auto
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
service-policy global_policy global
prompt hostname context
Cryptochecksum:7150eedc49ed0ed971b61f6be95ce9c0
: end
Solved! Go to Solution.
09-04-2011 11:31 PM
Any particular reason why you are using a router to connect to your internal network instead just connecting the ASA directly to your internal network?
Currently you have:
Any reason why you can't have:
Cable Modem --->ASA5505--->Switch
09-04-2011 11:31 PM
Currently you have:
09-04-2011 11:56 PM
I want security, so I use that as my firewall. Is that router slowing things down?
09-05-2011 12:07 AM
Are you not using the ASA firewall as your security appliance?
Router is just another routed hop which might slow it down a little, but it should not be that bad. However, you can just use the ASA as the firewall as it is a security device.
09-05-2011 04:44 AM
yeah totally agree with jennifer , that 3660 plays no useful function in your network -- with regards to your point about security -- from looking at the config -- it doesnt do any security , you should remove the router , re-address the inside interface of your ASA to ( ip address 192.168.1.1 255.255.255.0)
and do dhcp from your asa.. something like ...
dhcpd enable inside
dhcp address 192.168.1.20-192.168.1.220 inside
dhcp dns 192.168.1.x
your life will be a lot more easier and possible better performance as you will have one less device to go across
