Small Business mounting kit
brirmac87
I'm looking for a mounting kit for an SG 200-50P 50-Port Gigabit switch.  Or looking for the specific size for this switch.
B
Reza Sharifi
Are you planning to rack this switch in a cabinet? if yes, you need a set of mounting brackets. If you are racking it in a rack then the ear set that comes in the box is sufficient.
Thanks for the replay Reza,  Was planning on mounting it in a rack.  Unfortunately, i don't have the ear set,  that is what I was looking for.  I have decided just to use a rackmount tray.
B
