small system setup
solidground
Community Member
I have the following setup and wanted to make sure what I am conceptually doing is correct:
t1-1760router--2950switch---pix501
t1:
254 available ip's
1760 router
-no changes, just connected to the catalyst 2950 switch
2950 switch:
-Fedora Linux server for web hosting
-Windows Server 2003 Nic 1
-pix501
Pix501:
dhcp turned off
-windows server 2003 nic 2
-2 workstations
-network printer
Server 2003:
dhcp server
dns
vpn
terminal services
workstation access
Nic 1
terminal services
WAN access
Nic 2
LAN workstation access
vpn
Does this setup look correct?
thank you in advance
jarathbu
Level 4
Level 4
Looks fine. Are you going to have 2 separate VLANs for the different services associated with the 2nd NIC's and secure the public facing ones with the PIX and a totally private VLAN for the local services?
James
That is where I need help. Are you saying 3 vlans on the switch?
I have tried to draw your setup out, but I am not sure about the placement of the PIX. What is the main purpose of the PIX in your network ? Can you make a schematic drawing of your network and post it ?
Nethelper
