Smart Install Connectivity
Jure Knez
I'm trying to install Cisco 3560CG switch using Smart InstalI based on Connectivity. 3560CG is connected to Cisco 4500x (IOS 03.06.00.E.152-2.E) in port 15.
Here is the configuration:
4500x:
interface Vlan1
vstack vlan 1
vstack director 192.168.1.1
vstack basic
vstack startup-vlan 1
vstack group custom test connectivity
match host 192.168.1.1 interface TenGigabitEthernet1/15
This configuration is not working. I'm receiving this logs:
%SMI-6-INCORRECT_CFG: No image and config configured for this sku type WS-C3560CG-8TC-S
Any idea?
Debug on 4500x:
4500x#
Jan 26 09:36:58.040: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/15, changed state to up
Jan 26 09:37:00.040: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/15, changed state to up
Jan 26 09:37:01.630: VSTACK_DIR_DB: smi_parse_cdp_cache_entry: Mac addr received from cdp app tlv Neig mac ccd5.390f.be80, Local Mac c08c.60e0.2d10
Jan 26 09:37:01.630: VSTACK: smi_parse_cdp_cache_entry:processing the cdp pkt for mgmt vlan
 received vlan_plus_seqno=1, seq no for vlan = 0,prev_seq_no=65381 port_mode =0
smi_parse_cdp_cache_entry: Failed to get the supervisor info
Jan 26 09:37:01.630: VSTACK_DIR_DB: smi_parse_cdp_cache_entry:string in parse WS-C3560CG-8TC-S
Jan 26 09:37:01.630: VSTACK_DIR_DB: smi_enqueue_cdp_pkt_q_entry:IBC entry details are ....
Jan 26 09:37:01.630: VSTACK_DIR_DB: mac_add: ccd5.390f.be80, ip_add: 0.0.0.0,
           host_name : Switch, platform : WS-C3560CG-8TC-S , port_mac : c08c.60e0.2d10
Jan 26 09:37:01.630: VSTACK_DIR_DB: Ports : local TenGigabitEthernet1/15, out port GigabitEthernet0/10
Jan 26 09:37:01.630: VSTACK_DIR_DB:  Supervisor Model Type: NF
Jan 26 09:37:01.631: VSTACK_DIR_DB: smi_cdp_process:In process calling Handler for MSG typ 0
Jan 26 09:37:01.631: VSTACK_DIR_DB: smi_handle_cdp_event: ADD NEIGH EVENT
smi_handle_cdp_event: Switch(ccd5.390f.be80) replace type=Same Switch
Jan 26 09:37:01.631: VSTACK_PROTOCOL:
smi_version_compare: version string is Cisco IOS Software, C3560C Software (C3560c405ex-UNIVERSALK9-M), Version 15.2(2)E, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Thu 26-Jun-14 18:51 by prod_rel_team
Jan 26 09:37:01.631: VSTACK_DIR_DB: smi_chkpt_add_update_cdp_db_entry is called.
Jan 26 09:37:01.631: VSTACK_DIR_DB: smi_chkpt_add_update_cdp_db_entry: Switch is not active or invalid RED MODE!
Jan 26 09:37:01.631: VSTACK_DIR_DB: smi_cdp_add_red_links:Trying to ADD the RED Links ....
Jan 26 09:37:01.631: VSTACK_DIR_DB: Ports : local TenGigabitEthernet1/15, out port GigabitEthernet0/10
Jan 26 09:37:01.631: VSTACK_DIR_DB: Match Found
Jan 26 09:37:01.631: VSTACK_DIR_DB: Ports : local GigabitEthernet0/10, out port TenGigabitEthernet1/15
smi_check_init_disc_send_again: ibc ip zero, mac not present in queue, so enqueued ccd5.390f.be80 in the queue
Jan 26 09:37:02.061: VSTACK_DIR_DB: smi_parse_cdp_cache_entry: Mac addr received from cdp app tlv Neig mac ccd5.390f.be80, Local Mac c08c.60e0.2d10
Jan 26 09:37:02.061: VSTACK: smi_parse_cdp_cache_entry:processing the cdp pkt for mgmt vlan
 received vlan_plus_seqno=FF650001, seq no for vlan = 65381,prev_seq_no=65381 port_mode =0
Jan 26 09:37:02.061: VSTACK_DIR_DB: smi_parse_cdp_cache_entry:string in parse WS-C3560CG-8TC-S
Jan 26 09:37:02.061: VSTACK_DIR_DB: smi_enqueue_cdp_pkt_q_entry:IBC entry details are ....
Jan 26 09:37:02.061: VSTACK_DIR_DB: mac_add: ccd5.390f.be80, ip_add: 0.0.0.0,
Jan 26 09:37:02.061: VSTACK_DIR_DB: Ports : local TenGigabitEthernet1/15, out port GigabitEthernet0/10
Jan 26 09:37:02.061: VSTACK_DIR_DB:  Supervisor Model Type: NF
Jan 26 09:37:02.061: VSTACK_DIR_DB: smi_cdp_update_process:In process calling Handler for MSG typ 2
Jan 26 09:37:02.061: VSTACK_DIR_DB: smi_handle_cdp_event: UPDATE NEIGH EVENT
Jan 26 09:37:03.067: VSTACK_DIR_DB: smi_parse_cdp_cache_entry: Mac addr received from cdp app tlv Neig mac ccd5.390f.be80, Local Mac c08c.60e0.2d10
Jan 26 09:37:03.067: VSTACK: smi_parse_cdp_cache_entry:processing the cdp pkt for mgmt vlan
Jan 26 09:37:03.067: VSTACK_DIR_DB: smi_parse_cdp_cache_entry:string in parse WS-C3560CG-8TC-S
Jan 26 09:37:03.067: VSTACK_DIR_DB: smi_enqueue_cdp_pkt_q_entry:IBC entry details are ....
Jan 26 09:37:03.067: VSTACK_DIR_DB: mac_add: ccd5.390f.be80, ip_add: 0.0.0.0,
Jan 26 09:37:03.067: VSTACK_DIR_DB: Ports : local TenGigabitEthernet1/15, out port GigabitEthernet0/10
Jan 26 09:37:03.067: VSTACK_DIR_DB:  Supervisor Model Type: NF
Jan 26 09:37:03.067: VSTACK_DIR_DB: smi_cdp_update_process:In process calling Handler for MSG typ 2
Jan 26 09:37:03.067: VSTACK_DIR_DB: smi_handle_cdp_event: UPDATE NEIGH EVENT
Jan 26 09:37:04.068: VSTACK_DIR_DB: smi_parse_cdp_cache_entry: Mac addr received from cdp app tlv Neig mac ccd5.390f.be80, Local Mac c08c.60e0.2d10
Jan 26 09:37:04.068: VSTACK: smi_parse_cdp_cache_entry:processing the cdp pkt for mgmt vlan
Jan 26 09:37:04.068: VSTACK_DIR_DB: smi_parse_cdp_cache_entry:string in parse WS-C3560CG-8TC-S
Jan 26 09:37:04.068: VSTACK_DIR_DB: smi_enqueue_cdp_pkt_q_entry:IBC entry details are ....
Jan 26 09:37:04.068: VSTACK_DIR_DB: mac_add: ccd5.390f.be80, ip_add: 0.0.0.0,
Jan 26 09:37:04.068: VSTACK_DIR_DB: Ports : local TenGigabitEthernet1/15, out port GigabitEthernet0/10
Jan 26 09:37:04.068: VSTACK_DIR_DB:  Supervisor Model Type: NF
Jan 26 09:37:04.068: VSTACK_DIR_DB: smi_cdp_update_process:In process calling Handler for MSG typ 2
Jan 26 09:37:04.069: VSTACK_DIR_DB: smi_handle_cdp_event: UPDATE NEIGH EVENT
Jan 26 09:37:05.069: VSTACK_DIR_DB: smi_parse_cdp_cache_entry: Mac addr received from cdp app tlv Neig mac ccd5.390f.be80, Local Mac c08c.60e0.2d10
Jan 26 09:37:05.069: VSTACK: smi_parse_cdp_cache_entry:processing the cdp pkt for mgmt vlan
Jan 26 09:37:05.069: VSTACK_DIR_DB: smi_parse_cdp_cache_entry:string in parse WS-C3560CG-8TC-S
Jan 26 09:37:05.070: VSTACK_DIR_DB: smi_enqueue_cdp_pkt_q_entry:IBC entry details are ....
Jan 26 09:37:05.070: VSTACK_DIR_DB: mac_add: ccd5.390f.be80, ip_add: 0.0.0.0,
Jan 26 09:37:05.070: VSTACK_DIR_DB: Ports : local TenGigabitEthernet1/15, out port GigabitEthernet0/10
Jan 26 09:37:05.070: VSTACK_DIR_DB:  Supervisor Model Type: NF
Jan 26 09:37:05.070: VSTACK_DIR_DB: smi_cdp_update_process:In process calling Handler for MSG typ 2
Jan 26 09:37:05.070: VSTACK_DIR_DB: smi_handle_cdp_event: UPDATE NEIGH EVENT
Jan 26 09:37:06.070: VSTACK_DIR_DB: smi_parse_cdp_cache_entry: Mac addr received from cdp app tlv Neig mac ccd5.390f.be80, Local Mac c08c.60e0.2d10
Jan 26 09:37:06.071: VSTACK: smi_parse_cdp_cache_entry:processing the cdp pkt for mgmt vlan
Jan 26 09:37:06.071: VSTACK_DIR_DB:
Jan 26 09:37:06.071: VSTACK_DIR_DB: smi_parse_cdp_cache_entry:string in parse WS-C3560CG-8TC-S
Jan 26 09:37:06.071: VSTACK_DIR_DB: smi_enqueue_cdp_pkt_q_entry:IBC entry details are ....
Jan 26 09:37:06.071: VSTACK_DIR_DB: mac_add: ccd5.390f.be80, ip_add: 0.0.0.0,
Jan 26 09:37:06.071: VSTACK_DIR_DB: Ports : local TenGigabitEthernet1/15, out port GigabitEthernet0/10
Jan 26 09:37:06.071: VSTACK_DIR_DB:  Supervisor Model Type: NF
Jan 26 09:37:06.071: VSTACK_DIR_DB: smi_cdp_update_process:In process calling Handler for MSG typ 2
Jan 26 09:37:06.071: VSTACK_DIR_DB: smi_handle_cdp_event: UPDATE NEIGH EVENT
Jan 26 09:37:07.067: VSTACK_DIR_DB: smi_parse_cdp_cache_entry: Mac addr received from cdp app tlv Neig mac ccd5.390f.be80, Local Mac c08c.60e0.2d10
Jan 26 09:37:07.068: VSTACK: smi_parse_cdp_cache_entry:processing the cdp pkt for mgmt vlan
Jan 26 09:37:07.068: VSTACK_DIR_DB:
Jan 26 09:37:07.068: VSTACK_DIR_DB: smi_parse_cdp_cache_entry:string in parse WS-C3560CG-8TC-S
Jan 26 09:37:07.068: VSTACK_DIR_DB: smi_enqueue_cdp_pkt_q_entry:IBC entry details are ....
Jan 26 09:37:07.068: VSTACK_DIR_DB: mac_add: ccd5.390f.be80, ip_add: 0.0.0.0,
Jan 26 09:37:07.068: VSTACK_DIR_DB: Ports : local TenGigabitEthernet1/15, out port GigabitEthernet0/10
Jan 26 09:37:07.068: VSTACK_DIR_DB:  Supervisor Model Type: NF
Jan 26 09:37:07.068: VSTACK_DIR_DB: smi_cdp_update_process:In process calling Handler for MSG typ 2
Jan 26 09:37:07.068: VSTACK_DIR_DB: smi_handle_cdp_event: UPDATE NEIGH EVENT
Jan 26 09:37:08.069: VSTACK_DIR_DB: smi_parse_cdp_cache_entry: Mac addr received from cdp app tlv Neig mac ccd5.390f.be80, Local Mac c08c.60e0.2d10
Jan 26 09:37:08.069: VSTACK: smi_parse_cdp_cache_entry:processing the cdp pkt for mgmt vlan
Jan 26 09:37:08.069: VSTACK_DIR_DB: smi_parse_cdp_cache_entry:string in parse WS-C3560CG-8TC-S
Jan 26 09:37:08.070: VSTACK_DIR_DB: smi_enqueue_cdp_pkt_q_entry:IBC entry details are ....
Jan 26 09:37:08.070: VSTACK_DIR_DB: mac_add: ccd5.390f.be80, ip_add: 0.0.0.0,
Jan 26 09:37:08.070: VSTACK_DIR_DB: Ports : local TenGigabitEthernet1/15, out port GigabitEthernet0/10
Jan 26 09:37:08.070: VSTACK_DIR_DB:  Supervisor Model Type: NF
Jan 26 09:37:08.070: VSTACK_DIR_DB: smi_cdp_update_process:In process calling Handler for MSG typ 2
Jan 26 09:37:08.070: VSTACK_DIR_DB: smi_handle_cdp_event: UPDATE NEIGH EVENT
Jan 26 09:37:09.070: VSTACK_DIR_DB: smi_parse_cdp_cache_entry: Mac addr received from cdp app tlv Neig mac ccd5.390f.be80, Local Mac c08c.60e0.2d10
Jan 26 09:37:09.070: VSTACK: smi_parse_cdp_cache_entry:processing the cdp pkt for mgmt vlan
Jan 26 09:37:09.071: VSTACK_DIR_DB:
Jan 26 09:37:09.071: VSTACK_DIR_DB: smi_parse_cdp_cache_entry:string in parse WS-C3560CG-8TC-S
Jan 26 09:37:09.071: VSTACK_DIR_DB: smi_enqueue_cdp_pkt_q_entry:IBC entry details are ....
Jan 26 09:37:09.071: VSTACK_DIR_DB: mac_add: ccd5.390f.be80, ip_add: 0.0.0.0,
Jan 26 09:37:09.071: VSTACK_DIR_DB: Ports : local TenGigabitEthernet1/15, out port GigabitEthernet0/10
Jan 26 09:37:09.071: VSTACK_DIR_DB:  Supervisor Model Type: NF
Jan 26 09:37:09.071: VSTACK_DIR_DB: smi_cdp_update_process:In process calling Handler for MSG typ 2
Jan 26 09:37:09.071: VSTACK_DIR_DB: smi_handle_cdp_event: UPDATE NEIGH EVENT
Jan 26 09:37:10.072: VSTACK_DIR_DB: smi_parse_cdp_cache_entry: Mac addr received from cdp app tlv Neig mac ccd5.390f.be80, Local Mac c08c.60e0.2d10
Jan 26 09:37:10.072: VSTACK: smi_parse_cdp_cache_entry:processing the cdp pkt for mgmt vlan
Jan 26 09:37:10.072: VSTACK_DIR_DB: smi_parse_cdp_cache_entry:string in parse WS-C3560CG-8TC-S
Jan 26 09:37:10.072: VSTACK_DIR_DB: smi_enqueue_cdp_pkt_q_entry:IBC entry details are ....
Jan 26 09:37:10.072: VSTACK_DIR_DB: mac_add: ccd5.390f.be80, ip_add: 0.0.0.0,
Jan 26 09:37:10.072: VSTACK_DIR_DB: Ports : local TenGigabitEthernet1/15, out port GigabitEthernet0/10
Jan 26 09:37:10.072: VSTACK_DIR_DB:  Supervisor Model Type: NF
Jan 26 09:37:10.072: VSTACK_DIR_DB: smi_cdp_update_process:In process calling Handler for MSG typ 2
Jan 26 09:37:10.072: VSTACK_DIR_DB: smi_handle_cdp_event: UPDATE NEIGH EVENT
Jan 26 09:37:31.041: %LINK-3-UPDOWN: Interface Vlan1, changed state to up
Jan 26 09:37:31.041: %LINK-3-UPDOWN: Interface Vlan90, changed state to up
Jan 26 09:37:32.041: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to up
Jan 26 09:37:32.041: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan90, changed state to up
Jan 26 09:37:34.867: VSTACK_PROTOCOL:
smi_insert_dhcp_options: Inside DHCP options
smi_dhcp_shim_interesting_offer:No vstack options inserted, packet
                        may be flooded,
 out_vlan_id is 0
Jan 26 09:37:34.867: VSTACK_GROUP:
smi_get_img_cfg_from_mac: Input Mac address is: ccd5.390f.be80
Jan 26 09:37:34.867: VSTACK_DIR_DB:
smi_cdp_get_img_cfg_from_conn: Entry mac for connectivity ccd5.390f.be80
smi_cdp_get_img_cfg_from_conn: input port and ip TenGigabitEthernet1/15 192.168.1.1
smi_get_img_cfg_from_conn: Input address is: 192.168.1.1
 and interface is: TenGigabitEthernet1/15
smi_get_img_cfg_from_conn:input ip:192.168.1.1, list ip 192.168.1.1
smi_get_img_cfg_from_conn:input port TenGigabitEthernet1/15, list port TenGigabitEthernet1/15
Jan 26 09:37:34.868: VSTACK_GROUP:
smi_get_img_cfg_from_conn: error return:
smi_get_img_cfg_from_sku_id: Input Sku-id is: WS-C3560CG-8TC-S
smi_get_img_cfg_from_sku_id: Group is: test
smi_get_img_cfg_from_sku_id: error return
smi_get_img_cfg_from_sku: Sku is WS-C3560CG-8TC-S
smi_get_img_cfg_from_sku: Sku No 165
!!smi_get_group_info: Failed to get the CFG or IMG
Jan 26 09:37:34.868: VSTACK_PROTOCOL:
smi_ibd_get_image_config_name_from_chaddr: Did not match any group, the default group is also not configured
Jan 26 09:37:34.868: %SMI-6-INCORRECT_CFG: No image and config configured for this sku type WS-C3560CG-8TC-S
Jan 26 09:37:34.868: VSTACK_DOWNLOAD:
smi_client_entry_exists : client info against which we need to match : IP:178.172.78.99, MAC:ccd5.390f.be80
smi_client_entry_match_mac : current entry in list: IP:192.168.1.100, MAC:ccd5.390f.be80
 smi_client_entry_exists : the client_info is present in the client_info list
smi_prepare_option67: copied the tailored cfg file
smi_prepare_opt150: create the option 150 ip addr
smi_insert_dhcp_options:image name is , cfg name is
smi_prepare_opt125: create the option 125
!! smi_parse_cfg_img_file_dhcp_opt : server ip address not found
smi_prepare_opt125_subopt5: inserting dummy image file name
smi_prepare_opt125_subopt16: create the sub option 16 dir ip addr
smi_insert_dhcp_options: hostname option not present
smi_insert_dhcp_options: 1st option tftp (150)
smi_insert_dhcp_options: 2nd option tftp (150), 3rd option vendor (125)
Jan 26 09:37:34.874: VSTACK_PROTOCOL:
                        may be flooded,
 out_vlan_id is 0
Jan 26 09:37:34.875: VSTACK_GROUP:
Jan 26 09:37:34.875: VSTACK_DIR_DB:
Jan 26 09:37:34.875: VSTACK_PROTOCOL:
Jan 26 09:37:34.875: %SMI-6-INCORRECT_CFG: No image and config configured for this sku type WS-C3560CG-8TC-S
Jan 26 09:37:34.875: VSTACK_DOWNLOAD:
Jan 26 09:37:39.628: VSTACK_DIR_DB: smi_parse_cdp_cache_entry: Mac addr received from cdp app tlv Neig mac ccd5.390f.be80, Local Mac c08c.60e0.2d10
Jan 26 09:37:39.628: VSTACK: smi_parse_cdp_cache_entry:processing the cdp pkt for mgmt vlan
Jan 26 09:37:39.628: VSTACK_DIR_DB: smi_parse_cdp_cache_entry:string in parse WS-C3560CG-8TC-S
Jan 26 09:37:39.628: VSTACK_DIR_DB: smi_enqueue_cdp_pkt_q_entry:IBC entry details are ....
Jan 26 09:37:39.628: VSTACK_DIR_DB: mac_add: ccd5.390f.be80, ip_add: 192.168.1.100,
           host_name : ss-stps-tb.test.arnes.si, platform : WS-C3560CG-8TC-S , port_mac : c08c.60e0.2d10
Jan 26 09:37:39.628: VSTACK_DIR_DB: Ports : local TenGigabitEthernet1/15, out port GigabitEthernet0/10
Jan 26 09:37:39.628: VSTACK_DIR_DB:  Supervisor Model Type: NF
Jan 26 09:37:39.628: VSTACK_DIR_DB: smi_cdp_process:In process calling Handler for MSG typ 0
Jan 26 09:37:39.628: VSTACK_DIR_DB: smi_handle_cdp_event: ADD NEIGH EVENT
Jan 26 09:37:39.629: VSTACK_PROTOCOL:
Jan 26 09:37:39.629: VSTACK_DIR_DB: smi_chkpt_add_update_cdp_db_entry is called.
Jan 26 09:37:39.629: VSTACK_DIR_DB: smi_chkpt_add_update_cdp_db_entry: Switch is not active or invalid RED MODE!
Jan 26 09:37:39.629: VSTACK_DIR_DB: smi_cdp_add_red_links:Trying to ADD the RED Links ....
Jan 26 09:37:39.629: VSTACK_DIR_DB: Ports : local TenGigabitEthernet1/15, out port GigabitEthernet0/10
Jan 26 09:37:39.629: VSTACK_DIR_DB: Match Found
Jan 26 09:37:39.629: VSTACK_DIR_DB: Ports : local GigabitEthernet0/10, out port TenGigabitEthernet1/15
smi_check_init_disc_send_again: ibc ip(192.168.1.100) is non-zero, enqueued to ibc_update_q to send init_disc again
Jan 26 09:37:39.629: VSTACK_EMULATION:
smi_get_sku_type: passed string is WS-C3560CG-8TC-S
Jan 26 09:37:39.629: VSTACK_PROTOCOL: SI: client open successful
Jan 26 09:37:39.629: VSTACK_PROTOCOL: SI: memory set succesful
Jan 26 09:37:41.634: VSTACK_PROTOCOL: SI: socket connect successful
Jan 26 09:37:41.635: VSTACK_PROTOCOL:
smi_socket_open: socket is BLOCKING
 smi_send_data: data len is :36
 smi_send_data: from : 1
Jan 26 09:37:41.635: VSTACK_PROTOCOL: SMI: data send successfull of bytes: 52
Jan 26 09:37:41.635: VSTACK_PROTOCOL: SMI: Socket close successfull
 smi_ibd_send_ibd_init_disc: Successfully send the IBD Init Discovery Message to IBC : 192.168.1.100
Jan 26 09:37:54.272: VSTACK_PROTOCOL: smi_ibd_comm_server_socket: Socket accept succesfull
Jan 26 09:37:54.272: VSTACK_FSM: 33, ../VIEW_ROOT/cisco.comp/smartinstall/src/smi_ibd_serv_sm.c, ibds_create_action
smi_ibds_sm_init: SMI_IBDS fsm init SUCCESS
Jan 26 09:37:54.272: VSTACK_FSM: 40, ../VIEW_ROOT/cisco.comp/smartinstall/src/smi_ibd_serv_sm.c, ibds_accept_action
Jan 26 09:37:54.272: VSTACK_FSM: 53, ../VIEW_ROOT/cisco.comp/smartinstall/src/smi_ibd_serv_sm.c, ibds_send_ann_action
 smi_ibd_comm_server_socket: FSM created for the client
Jan 26 09:37:54.273: VSTACK_PROTOCOL:
 smi_sm_get_conn_from_fd : the fd is present in the conn fd list
 smi_socket_recv_read_hdr : Complete Header Read : 16
smi_socket_recv_read_hdr: Message type=1, ip=192.168.1.100
smi_compare_msg_hdr_type:ibc msg_hdr type is 1
smi_socket_recv_read_hdr : data length = 692
Jan 26 09:37:54.274: VSTACK_PROTOCOL:
smi_socket_read_start: header read complete, next data read
smi_handle_recv_msg: SMI_MSG_FRM_IBC_CLI
smi_set_ibc_version_info: message header version=1
smi_set_ibc_version_info: Device(ccd5.390f.be80) smi version(1) is being updated to 1
 smi_handle_ibd_recv_msg : 1 type received
Jan 26 09:37:54.274: VSTACK_FSM: 58, ../VIEW_ROOT/cisco.comp/smartinstall/src/smi_ibd_serv_sm.c, ibds_recv_cdp_action
Jan 26 09:37:54.274: VSTACK_DIR_DB: smi_cdp_msg_handler:Got the Msg Len as 692 & readptr:1549863432 & endptr:1549864124
Jan 26 09:37:54.274: VSTACK_DIR_DB: smi_cdp_msg_handler:Curr readptr:1549863436 & endptr:1549864124
Jan 26 09:37:54.274: VSTACK_DIR_DB: smi_cdp_msg_handler:Got the TLV type as 1 and TLV len as 16 & buff is 672
Jan 26 09:37:54.274: VSTACK_DIR_DB: smi_get_cdp_msg_seq_tlv:The header info is..msg:1, msg_count:2, mac:ccd5.390f.be80
Jan 26 09:37:54.274: VSTACK_DIR_DB: smi_cdp_msg_handler:Allocating the mme for cdp update
Jan 26 09:37:54.274: VSTACK_DIR_DB: smi_cdp_msg_handler:Got the data as msgs :2, mac:ccd5.390f.be80
Jan 26 09:37:54.274: VSTACK_DIR_DB: smi_cdp_msg_handler:Curr readptr:1549863456 & endptr:1549864124
Jan 26 09:37:54.274: VSTACK_DIR_DB: smi_cdp_msg_handler:Got the TLV type as 2 and TLV len as 668 & buff is 0
Jan 26 09:37:54.274: VSTACK_DIR_DB: smi_get_ibc_info_tlv:IBC contents are mac ccd5.390f.be80, host_name :ss-stps-tb, sku: WS-C3560CG-8TC-S, serial: FOC1644Y62J
Jan 26 09:37:54.274: VSTACK_DIR_DB: smi_cdp_msg_handler:TLV_TYPE_IBC with contents mac ccd5.390f.be80,
Jan 26 09:37:54.274: VSTACK_DIR_DB: smi_cdp_msg_handler:Adding the data to RCV Q
Jan 26 09:37:54.274: VSTACK_FSM: 81, ../VIEW_ROOT/cisco.comp/smartinstall/src/smi_ibd_serv_sm.c, ibds_exit_action
Jan 26 09:37:54.274: VSTACK_FSM: 48, ../VIEW_ROOT/cisco.comp/smartinstall/src/smi_ibd_serv_sm.c, ibds_close_conn_action
 smi_socket_recv_data: Complete read of data has happened
Jan 26 09:37:54.276: VSTACK_PROTOCOL: smi_ibd_comm_server_socket: Socket accept succesfull
Jan 26 09:37:54.276: VSTACK_FSM: 33, ../VIEW_ROOT/cisco.comp/smartinstall/src/smi_ibd_serv_sm.c, ibds_create_action
Jan 26 09:37:54.277: VSTACK_FSM:
Jan 26 09:37:54.277: VSTACK_FSM: 40, ../VIEW_ROOT/cisco.comp/smartinstall/src/smi_ibd_serv_sm.c, ibds_accept_action
Jan 26 09:37:54.277: VSTACK_FSM: 53, ../VIEW_ROOT/cisco.comp/smartinstall/src/smi_ibd_serv_sm.c, ibds_send_ann_action
Jan 26 09:37:54.277: VSTACK_PROTOCOL:
Jan 26 09:37:54.278: VSTACK_PROTOCOL:
smi_socket_recv_read_hdr : data length = 708
Jan 26 09:37:54.278: VSTACK_FSM: 58, ../VIEW_ROOT/cisco.comp/smartinstall/src/smi_ibd_serv_sm.c, ibds_recv_cdp_action
Jan 26 09:37:54.278: VSTACK_DIR_DB: smi_cdp_msg_handler:Got the Msg Len as 708 & readptr:1552268480 & endptr:1552269188
Jan 26 09:37:54.278: VSTACK_DIR_DB: smi_cdp_msg_handler:Curr readptr:1552268484 & endptr:1552269188
Jan 26 09:37:54.278: VSTACK_DIR_DB: smi_cdp_msg_handler:Got the TLV type as 1 and TLV len as 16 & buff is 688
Jan 26 09:37:54.278: VSTACK_DIR_DB: smi_get_cdp_msg_seq_tlv:The header info is..msg:2, msg_count:2, mac:ccd5.390f.be80
Jan 26 09:37:54.278: VSTACK_DIR_DB: smi_cdp_msg_handler:Found the CDP Entry in RCV Q for ccd5.390f.be80
Jan 26 09:37:54.278: VSTACK_DIR_DB: smi_cdp_msg_handler:Got the data as msgs :2, mac:ccd5.390f.be80
Jan 26 09:37:54.278: VSTACK_DIR_DB: smi_cdp_msg_handler:Curr readptr:1552268504 & endptr:1552269188
Jan 26 09:37:54.278: VSTACK_DIR_DB: smi_cdp_msg_handler:Got the TLV type as 4 and TLV len as 684 & buff is 0
Jan 26 09:37:54.278: VSTACK_DIR_DB: smi_get_neighbor_info_tlv: Got the Nei count as 1 & alloc mem of 684
Jan 26 09:37:54.278: VSTACK_DIR_DB: smi_cdp_msg_handler:Fill TLV_TYPE_NEI with contents  mac c08c.60e0.2d10,
                       host_name :4500x, sku: WS-C4500X-16, sup: WS-C4500X-16, port_mac: ccd5.390f.be80, ports->local :GigabitEthernet0/10,
                       out :TenGigabitEthernet1/15
Jan 26 09:37:54.278: VSTACK_DIR_DB: smi_cdp_msg_handler: Enqueuing to the process fromRCV Q
Jan 26 09:37:54.278: VSTACK_FSM: 81, ../VIEW_ROOT/cisco.comp/smartinstall/src/smi_ibd_serv_sm.c, ibds_exit_action
Jan 26 09:37:54.278: VSTACK_FSM: 48, ../VIEW_ROOT/cisco.comp/smartinstall/src/smi_ibd_serv_sm.c, ibds_close_conn_action
Jan 26 09:37:54.279: VSTACK_PROTOCOL:
Jan 26 09:37:54.279: VSTACK_DIR_DB: smi_chkpt_add_update_cdp_db_entry is called.
Jan 26 09:37:54.279: VSTACK_DIR_DB: smi_chkpt_add_update_cdp_db_entry: Switch is not active or invalid RED MODE!
smi_ibd_cdp_announcment_msg_handling:Got announcement msg from switch(ccd5.390f.be80)
Jan 26 09:37:54.279: VSTACK:
 IBD= Send UPD MGMT VLAN Req MSG from IBD:192.168.1.1 to IBC:192.168.1.100
Jan 26 09:37:54.279: VSTACK_PROTOCOL: SI: client open successful
Jan 26 09:37:54.279: VSTACK_PROTOCOL: SI: memory set succesful
Jan 26 09:37:54.284: VSTACK_PROTOCOL: SI: socket connect successful
 smi_send_data: data len is :4
Jan 26 09:37:54.284: VSTACK_PROTOCOL: SMI: data send successfull of bytes: 20
Jan 26 09:37:54.284: VSTACK_PROTOCOL: SMI: Socket close successfull
smi_version_compare2: version string is Cisco IOS Software, C3560C Software (C3560c405ex-UNIVERSALK9-M), Version 15.2(2)E, RELEASE SOFTWARE (fc3)
smi_version_compare2: ver is 2
smi_version_compare2 : value is 2
Jan 26 09:37:54.284: VSTACK_DIR_DB:
smi_ibd_cdp_announcment_msg_handling:Checking if the neighbor(c08c.60e0.2d10) is replaced
smi_check_if_switch_is_replaced:Rep - cfg_bkp_feature is ON
smi_check_if_switch_is_replaced:Rep - local_port=GigabitEthernet0/10, out_port=TenGigabitEthernet1/15
smi_same_sku_exists_at_port:Rep: neighbor mac=ccd5.390f.be80, new sku=WS-C4500X-16, port attached=GigabitEthernet0/10
Jan 26 09:37:54.285: VSTACK_DIR_DB:
smi_same_sku_exists_at_port:Rep: input port GigabitEthernet0/10, target port GigabitEthernet0/10, port Matched
smi_same_sku_exists_at_port:Rep: input platform WS-C4500X-16, target platform WS-C4500X-16
smi_same_sku_exists_at_port:Rep: input mac c08c.60e0.2d10, target mac c08c.60e0.2d10
smi_same_sku_exists_at_port:Rep: sku also matched
smi_same_sku_exists_at_port:Rep: Mac(c08c.60e0.2d10) matched. So its same switch
smi_check_if_switch_is_replaced:c08c.60e0.2d10 either not a replacement or else same switch
smi_ibd_cdp_announcment_msg_handling: Switch(c08c.60e0.2d10) replace type=Same Switch
smi_ibd_cdp_announcment_msg_handling:***Check if neighbor need to be added again***
smi_ibd_cdp_announcment_msg_handling:Neighbor entry found, will update it
Jan 26 09:37:54.285: VSTACK_DIR_DB: smi_cdp_add_red_links:Trying to ADD the RED Links ....
Jan 26 09:37:54.285: VSTACK_DIR_DB: Ports : local TenGigabitEthernet1/15, out port GigabitEthernet0/10
Jan 26 09:37:54.285: VSTACK_DIR_DB: Match Found
Jan 26 09:37:54.285: VSTACK_DIR_DB: Ports : local GigabitEthernet0/10, out port TenGigabitEthernet1/15
Jan 26 09:37:54.285: VSTACK_DIR_DB: smi_calc_hop_value: GO the Best Hop as 0 for ss-stps-tb
Jan 26 09:37:54.285: VSTACK_DIR_DB: smi_calc_hop_value: Returning with HOP as 1 for ss-stps-tb
Jan 26 09:38:01.188: VSTACK_DIR_DB: smi_parse_cdp_cache_entry: Mac addr received from cdp app tlv Neig mac ccd5.390f.be80, Local Mac c08c.60e0.2d10
Jan 26 09:38:01.188: VSTACK: smi_parse_cdp_cache_entry:processing the cdp pkt for mgmt vlan
 received vlan_plus_seqno=29F0001, seq no for vlan = 671,prev_seq_no=65381 port_mode =0
Jan 26 09:38:01.188: VSTACK_DIR_DB: smi_parse_cdp_cache_entry:string in parse WS-C3560CG-8TC-S
Jan 26 09:38:01.189: VSTACK_DIR_DB: smi_enqueue_cdp_pkt_q_entry:IBC entry details are ....
Jan 26 09:38:01.189: VSTACK_DIR_DB: mac_add: ccd5.390f.be80, ip_add: 192.168.1.100,
Jan 26 09:38:01.189: VSTACK_DIR_DB: Ports : local TenGigabitEthernet1/15, out port GigabitEthernet0/10
Jan 26 09:38:01.189: VSTACK_DIR_DB:  Supervisor Model Type: NF
Jan 26 09:38:01.189: VSTACK_DIR_DB: smi_cdp_update_process:In process calling Handler for MSG typ 2
Jan 26 09:38:01.189: VSTACK_DIR_DB: smi_handle_cdp_event: UPDATE NEIGH EVENT
smi_check_init_disc_send_again: neighbor ip 192.168.1.100, discovery queue could be empty, so not checking if discovery msg needs to be sent again
Jan 26 09:38:01.189: VSTACK_PROTOCOL:
Jan 26 09:38:01.189: VSTACK_DIR_DB: smi_chkpt_add_update_cdp_db_entry is called.
Jan 26 09:38:01.189: VSTACK_DIR_DB: smi_chkpt_add_update_cdp_db_entry: Switch is not active or invalid RED MODE!
Jan 26 09:38:03.301: VSTACK_PROTOCOL: smi_ibd_comm_server_socket: Socket accept succesfull
Jan 26 09:38:03.301: VSTACK_FSM: 33, ../VIEW_ROOT/cisco.comp/smartinstall/src/smi_ibd_serv_sm.c, ibds_create_action
Jan 26 09:38:03.301: VSTACK_FSM: 40, ../VIEW_ROOT/cisco.comp/smartinstall/src/smi_ibd_serv_sm.c, ibds_accept_action
Jan 26 09:38:03.301: VSTACK_FSM: 53, ../VIEW_ROOT/cisco.comp/smartinstall/src/smi_ibd_serv_sm.c, ibds_send_ann_action
Jan 26 09:38:03.302: VSTACK_PROTOCOL:
smi_socket_recv_read_hdr: Message type=6, ip=192.168.1.100
smi_compare_msg_hdr_type:ibc msg_hdr type is 6
smi_set_ibc_version_info: message header version=0
smi_set_ibc_version_info: Device(ccd5.390f.be80) smi version(1) is being updated to 0
 smi_handle_ibd_recv_msg : 6 type received
 smi_ibd_handle_version_req : Received Version Request from IBC(192.168.1.100)
 smi_ibds_process_version_req: received version request info
Jan 26 09:38:03.302: VSTACK_FSM: 68, ../VIEW_ROOT/cisco.comp/smartinstall/src/smi_ibd_serv_sm.c, ibds_recv_ver_req
Jan 26 09:38:03.302: VSTACK_GROUP:
Jan 26 09:38:03.303: VSTACK_DIR_DB:
Jan 26 09:38:03.303: VSTACK_GROUP:
Jan 26 09:38:03.303: VSTACK_PROTOCOL:
!!smi_ibds_process_version_req: Failed to get the cfg
Jan 26 09:38:03.303: VSTACK_DOWNLOAD:
smi_client_entry_exists : client info against which we need to match : IP:192.168.1.100, MAC:ccd5.390f.be80
smi_new_client_info_add_to_dl_status_list : Overriding an existing entry that is still upgrading
smi_new_client_info_add_to_dl_status_list client MAC exists, need not enqueue
Jan 26 09:38:03.303: VSTACK_DIR_DB: smi_chkpt_update_database: Message 28 received.
Jan 26 09:38:03.304: VSTACK_DIR_DB: smi_chkpt_update_database: Switch is not Active or Invalid RED MODE!
Jan 26 09:38:03.304: VSTACK_PROTOCOL:
smi_ibd_send_ver_resp: send version info data from IBC
Jan 26 09:38:03.304: VSTACK_FSM: 81, ../VIEW_ROOT/cisco.comp/smartinstall/src/smi_ibd_serv_sm.c, ibds_exit_action
Jan 26 09:38:03.304: VSTACK_FSM: 48, ../VIEW_ROOT/cisco.comp/smartinstall/src/smi_ibd_serv_sm.c, ibds_close_conn_action
Jan 26 09:38:03.305: VSTACK_PROTOCOL:
Jan 26 09:38:03.367: VSTACK_PROTOCOL: smi_ibd_comm_server_socket: Socket accept succesfull
Jan 26 09:38:03.367: VSTACK_FSM: 33, ../VIEW_ROOT/cisco.comp/smartinstall/src/smi_ibd_serv_sm.c, ibds_create_action
Jan 26 09:38:03.367: VSTACK_FSM: 40, ../VIEW_ROOT/cisco.comp/smartinstall/src/smi_ibd_serv_sm.c, ibds_accept_action
Jan 26 09:38:03.367: VSTACK_FSM: 53, ../VIEW_ROOT/cisco.comp/smartinstall/src/smi_ibd_serv_sm.c, ibds_send_ann_action
smi_socket_recv_read_hdr: Message type=7, ip=192.168.1.100
smi_compare_msg_hdr_type:ibc msg_hdr type is 7
smi_socket_recv_read_hdr : data length = 416
Jan 26 09:38:03.368: VSTACK_PROTOCOL:
smi_set_ibc_version_info: Device(ccd5.390f.be80) smi version(0) is being updated to 1
 smi_handle_ibd_recv_msg : 7 type received
Jan 26 09:38:03.368: VSTACK_GROUP:
smi_ibd_handle_upgrade_msg:Client ip from up_msg and connection are 192.168.1.100 192.168.1.100
Jan 26 09:38:03.368: %SMI-3-UPGRD_FAILED: Device (IP address: 192.168.1.100) image upgrade failed
Jan 26 09:38:03.368: VSTACK_JW:
smi_set_cfg_img_upgrade_status: img_status 2 cfg_status 5, spt_status 5, in_ql_jw now is 3
Jan 26 09:38:03.368: VSTACK_DOWNLOAD:
 smi_edit_cfg_img_upgrade_status : the client is upgrading yet
 smi_delete_tar_image_list : the client_info is present in the client_info list
Jan 26 09:38:03.368: VSTACK_FSM: 81, ../VIEW_ROOT/cisco.comp/smartinstall/src/smi_ibd_serv_sm.c, ibds_exit_action
Jan 26 09:38:03.368: VSTACK_FSM: 48, ../VIEW_ROOT/cisco.comp/smartinstall/src/smi_ibd_serv_sm.c, ibds_close_conn_action
Jan 26 09:38:04.984: VSTACK_PROTOCOL: smi_ibd_comm_server_socket: Socket accept succesfull
Jan 26 09:38:04.984: VSTACK_FSM: 33, ../VIEW_ROOT/cisco.comp/smartinstall/src/smi_ibd_serv_sm.c, ibds_create_action
Jan 26 09:38:04.984: VSTACK_FSM: 40, ../VIEW_ROOT/cisco.comp/smartinstall/src/smi_ibd_serv_sm.c, ibds_accept_action
Jan 26 09:38:04.984: VSTACK_FSM: 53, ../VIEW_ROOT/cisco.comp/smartinstall/src/smi_ibd_serv_sm.c, ibds_send_ann_action
Jan 26 09:38:04.985: VSTACK_PROTOCOL:
Jan 26 09:38:04.986: VSTACK_PROTOCOL:
Jan 26 09:38:04.986: VSTACK_FSM: 58, ../VIEW_ROOT/cisco.comp/smartinstall/src/smi_ibd_serv_sm.c, ibds_recv_cdp_action
Jan 26 09:38:04.986: VSTACK_DIR_DB: smi_cdp_msg_handler:Got the Msg Len as 692 & readptr:1549036272 & endptr:1549036964
Jan 26 09:38:04.986: VSTACK_DIR_DB: smi_cdp_msg_handler:Curr readptr:1549036276 & endptr:1549036964
Jan 26 09:38:04.986: VSTACK_DIR_DB: smi_cdp_msg_handler:Got the TLV type as 1 and TLV len as 16 & buff is 672
Jan 26 09:38:04.986: VSTACK_DIR_DB: smi_get_cdp_msg_seq_tlv:The header info is..msg:1, msg_count:2, mac:ccd5.390f.be80
Jan 26 09:38:04.986: VSTACK_DIR_DB: smi_cdp_msg_handler:Allocating the mme for cdp update
Jan 26 09:38:04.986: VSTACK_DIR_DB: smi_cdp_msg_handler:Got the data as msgs :2, mac:ccd5.390f.be80
Jan 26 09:38:04.986: VSTACK_DIR_DB: smi_cdp_msg_handler:Curr readptr:1549036296 & endptr:1549036964
Jan 26 09:38:04.986: VSTACK_DIR_DB: smi_cdp_msg_handler:Got the TLV type as 2 and TLV len as 668 & buff is 0
Jan 26 09:38:04.986: VSTACK_DIR_DB: smi_get_ibc_info_tlv:IBC contents are mac ccd5.390f.be80, host_name :ss-stps-tb, sku: WS-C3560CG-8TC-S, serial: FOC1644Y62J
Jan 26 09:38:04.986: VSTACK_DIR_DB: smi_cdp_msg_handler:TLV_TYPE_IBC with contents mac ccd5.390f.be80,
Jan 26 09:38:04.986: VSTACK_DIR_DB: smi_cdp_msg_handler:Adding the data to RCV Q
Jan 26 09:38:04.986: VSTACK_FSM: 81, ../VIEW_ROOT/cisco.comp/smartinstall/src/smi_ibd_serv_sm.c, ibds_exit_action
Jan 26 09:38:04.986: VSTACK_FSM: 48, ../VIEW_ROOT/cisco.comp/smartinstall/src/smi_ibd_serv_sm.c, ibds_close_conn_action
Jan 26 09:38:04.989: VSTACK_PROTOCOL: smi_ibd_comm_server_socket: Socket accept succesfull
Jan 26 09:38:04.989: VSTACK_FSM: 33, ../VIEW_ROOT/cisco.comp/smartinstall/src/smi_ibd_serv_sm.c, ibds_create_action
Jan 26 09:38:04.989: VSTACK_FSM: 40, ../VIEW_ROOT/cisco.comp/smartinstall/src/smi_ibd_serv_sm.c, ibds_accept_action
Jan 26 09:38:04.989: VSTACK_FSM: 53, ../VIEW_ROOT/cisco.comp/smartinstall/src/smi_ibd_serv_sm.c, ibds_send_ann_action
Jan 26 09:38:04.990: VSTACK_PROTOCOL:
Jan 26 09:38:04.990: VSTACK_FSM: 58, ../VIEW_ROOT/cisco.comp/smartinstall/src/smi_ibd_serv_sm.c, ibds_recv_cdp_action
Jan 26 09:38:04.990: VSTACK_DIR_DB: smi_cdp_msg_handler:Got the Msg Len as 708 & readptr:1545645368 & endptr:1545646076
Jan 26 09:38:04.990: VSTACK_DIR_DB: smi_cdp_msg_handler:Curr readptr:1545645372 & endptr:1545646076
Jan 26 09:38:04.990: VSTACK_DIR_DB: smi_cdp_msg_handler:Got the TLV type as 1 and TLV len as 16 & buff is 688
Jan 26 09:38:04.990: VSTACK_DIR_DB: smi_get_cdp_msg_seq_tlv:The header info is..msg:2, msg_count:2, mac:ccd5.390f.be80
Jan 26 09:38:04.990: VSTACK_DIR_DB: smi_cdp_msg_handler:Found the CDP Entry in RCV Q for ccd5.390f.be80
Jan 26 09:38:04.990: VSTACK_DIR_DB: smi_cdp_msg_handler:Got the data as msgs :2, mac:ccd5.390f.be80
Jan 26 09:38:04.990: VSTACK_DIR_DB: smi_cdp_msg_handler:Curr readptr:1545645392 & endptr:1545646076
Jan 26 09:38:04.990: VSTACK_DIR_DB: smi_cdp_msg_handler:Got the TLV type as 4 and TLV len as 684 & buff is 0
Jan 26 09:38:04.990: VSTACK_DIR_DB: smi_get_neighbor_info_tlv: no Got the Nei count as 1 & alloc mem of 684
Jan 26 09:38:04.990: VSTACK_DIR_DB: smi_cdp_msg_handler:Fill TLV_TYPE_NEI with contents  mac c08c.60e0.2d10,
Jan 26 09:38:04.990: VSTACK_DIR_DB: smi_cdp_msg_handler: Enqueuing to the process fromRCV Q
Jan 26 09:38:04.990: VSTACK_FSM: 81, ../VIEW_ROOT/cisco.comp/smartinsdebu tall/src/smi_ibd_serv_sm.c, ibds_exit_action
Jan 26 09:38:04.991: VSTACK_FSM: 48, ../VIEW_ROOT/cisco.comp/smartinstall/src/smi_ibd_serv_sm.c, ibds_close_conn_action
Jan 26 09:38:04.991: VSTACK_PROTOCOL:
Jan 26 09:38:04.991: VSTACK_DIR_DB: smi_chkpt_add_update_cdp_db_entry is called.
Jan 26 09:38:04.991: VSTACK_DIR_DB: smi_chkpt_add_update_cdp_db_entry: Switch is not active or invalid RED MODE!
smi_ibd_cdpall
All possible debugging has been turned off
4500x#_announcment_msg_handling:Got announcement msg from switch(ccd5.390f.be80)
Jan 26 09:38:04.991: VSTACK:
Jan 26 09:38:04.991: VSTACK_PROTOCOL: SI: client open successful
Jan 26 09:38:04.991: VSTACK_PROTOCOL: SI: memory set succesful
Jan 26 09:38:04.996: VSTACK_PROTOCOL: SI: socket connect successful
Jan 26 09:38:04.996: VSTACK_PROTOCOL: SMI: data send successfull of bytes: 20
Jan 26 09:38:04.996: VSTACK_PROTOCOL: SMI: Socket close successfull
Jan 26 09:38:04.996: VSTACK_DIR_DB:
Jan 26 09:38:04.997: VSTACK_DIR_DB:
Jan 26 09:38:04.997: VSTACK_DIR_DB: smi_cdp_add_red_links:Trying to ADD the RED Links ....
Jan 26 09:38:04.997: VSTACK_DIR_DB: Ports : local TenGigabitEthernet1/15, out port GigabitEthernet0/10
Jan 26 09:38:04.997: VSTACK_DIR_DB: Match Found
Jan 26 09:38:04.997: VSTACK_DIR_DB: Ports : local GigabitEthernet0/10, out port TenGigabitEthernet1/15
Jan 26 09:38:04.997: VSTACK_DIR_DB: smi_calc_hop_value: GO the Best Hop as 0 for ss-stps-tb
Jan 26 09:38:04.997: VSTACK_DIR_DB: smi_calc_hop_value: Returning with HOP as 1 for ss-stps-tb
Jan 26 09:38:07.942: VSTno ACK_PROTOCOL:
Jan 26 09:38:07.942: VSTACK_PROTOCOL:
Jan 26 09:38:07.942: VSTACK_GROUP:
Jan 26 09:38:0debu7.942: VSTACK_DIR_DB:
Jan 26 09:38:07.942: VSTACK_DIR_DB:
Jang all 26 09:38:07.942: VSTACK_GROUP:
sm
4500x#i_get_img_cfg_from_sku: Sku is WS-C3560CG-8TC-S
Jan 26 09:38:07.943: VSTACK_GROUP:
Jan 26 09:38:07.943: VSTACK_PROTOCOL:
Jan 26 09:38:07.943: %SMI-6-INCORRECT_CFG: No image and config configured for this sku type WS-C3560CG-8TC-S
Jan 26 09:38:07.943: VSTACK_DOWNLOAD:
4500x#16 dir ip addr
Jan 26 09:38:39.009: VSTACK_PROTOCOL:
Jan 26 09:38:39.010: VSTACK_GROUP:
Jan 26 09:38:39.010: VSTACK_DIR_DB:
Jan 26 09:38:39.010: VSTACK_PROTOCOL:
Jan 26 09:38:39.010: %SMI-6-INCORRECT_CFG: No image and config configured for this sku type WS-C3560CG-8TC-S
Jan 26 09:38:39.010: VSTACK_DOWNLOAD:
image bootflash:c3560c405ex-universalk9-tar.152-2.E.tar
Did you enable TFTP of this image?
This is still incorrect.  How will the switch know what model this is meant to be?
What files do you have for this?  You need a minimum of THREE files (excluding the post-install script) ... what a second.  Post install script is not supported until 3.7.0E.  Just checked my notes and found that Post Install Script feature was enabled back in 3.6.0E so you're running the correct IOS.
Another thing, how do you know what is the IP address of the 3560CG?  Where's your DHCP pool for VStack?
Have you read link I've posted?  It contains a guide to configure custom group.   Please read it and don't "re-invent the wheel".
9 Replies 9
Leo Laohoo
I would expect this message.  The configuration of the VStack has a lot of missing configuration.  You've got a 3560CG but where is your VStack built-in group?  Where is your TFTP server?  Where are the configuration template file location?  Where is the IOS file location?
Have a look at THIS.
I'm not using VStack built-in group but Vstack custom group.
 config bootflash:test.txt
 script bootflash:test_vlan.txt
tftp-server bootflash:c3560c405ex-universalk9-tar.152-2.E.tar
tftp-server bootflash:test.txt tftp-server
I just want to configure switch on port 15. Switches on specific port receives specific configuration.
DHCP is configured on DHCP server. Switch gets IP depending from which port on switch came request.
There is no Cisco switch model called "test".  If you want to enable VStack for a 3560CG then you'll need to do something like this:
vstack group built-in 3560cg 8-pd-poe
VStack looks at the CDP values and extrapolate the necessary data.  Because 3560CG is already part of VStack, you can set it up this way.  The only time you want to use the custom group is when your switch are not supported, such as Metro Ethernet switches.
I understand you may just be testing stuff but I would urge you to exercise a large degree of caution (and a dose of sanity).  I've tested this IOS.   I've also tested this IOS on the 3560CG-8P ... and if I was to put a rating between 0 to 10 (10 being the highest), I'd rate this version a NEGATIVE 9!
What about this:
You can configure a custom group based on the connectivity or topology of switches in a Smart Install network. For example, you would use a connectivity match to configure a group of switches that are connected to the director through a single interface or switches that are connected to the director through a specific intermediate switch. A connectivity match takes priority over product ID or stack number custom groups and over built-in groups, but not over groups based on MAC addresses. Switches that do not match the connectivity configuration would acquire the configuration file, post install file, and image in either a built-in group or through the default configuration.
Director# configure terminal
Director(config)# vstack director 1.1.1.20
Director(config)# vstack basic
Director(config)# vstack group custom textgroup2 connectivity
Director(config-vstack-group)# match host 1.1.1.10 interface GigabitEthernet 1/0/3
Director(config-vstack-group)# image tftp://101.122.33.10/c3750-ipbase-tar.122-52.SE.tar
Director(config-vstack-group)# config tftp://101.122.33.10/3750-24-ipbase_config.txt
Director(config-vstack-group)# script tftp://101.122.33.10/3750-24-ipbase_post_install.txt
Director(config-vstack-group)# exit
This is from http://www.cisco.com/c/en/us/td/docs/switches/lan/smart_install/configuration/guide/smart_install.pdf
I don't understand what you are doing.
So are you saying, "whatever is connected to port 15 will get the IOS for 3560CG and the configuration for 3560CG"?  Are you sure that only a 3560CG can/will connect to port 15?  What if someone connects a 2960S-24PDL?
How many associated files do you have and what are they?
I know which device will connect to port 15. Only one type of switches will connect. I have configuration file, IOS and post install for VLAN-s. Switch on specific port receives specific configuration.
Then you're missing one file.  Read the link I've posted.   You should have FOUR (4) files (including the post-install script).
I've never implemented what you are doing because of all the SmartInstall I've done, none of them have wanted this method.
