Beginner
Smart license cat9k
I have registered the license on new catalyst 9300 model using smart license manager portal. Now it is not possible to connect the switch again to internet or to use proxy methods to send license usage . I am not using any DNA product in my environment. So only using routing and switching part.
My question is , what is going to happen ? Is the switch going to continue working properly ?
5 REPLIES 5
VIP Expert
Re: Smart license cat9k
Yes, the switch will work with no issues. You don't have to be connected to the Internet.
Beginner
Thanks a lot Reza for reply !  I need to deploy couple of distribution switches in other locations and I was doubting about license issue  thinking of ordering other type or other vendor. Now I will go ahead and deploy CAT9Ks
VIP Expert
You should be fine. With licenses, as long as they are valid, usually, you configure and apply it once. The license stays the same even with IOS upgrades.
Good Luck!
Beginner
Hi Reza
in the similar situation of having no DNA etc advantage stuff i cant see _basic_ licensing on the Cat9300 switch :0)
could u please advice where to look/dig? :0)
evaluation (hopefuly only DNA stuff) will expire in few days (i'm on the deployment for few days meantime :0).
i'm interesting only in IBNS 2.0 full feature-set.
Fuji 16.9.2
Technology Package License Information:
Technology-package Technology-package
Current Type Next reboot
network-advantage Smart License network-advantage
dna-advantage Subscription Smart License dna-advantage
#sho license all
Smart Licensing Status
Smart Licensing is ENABLED
Registration:
Status: UNREGISTERED
Export-Controlled Functionality: Not Allowed
License Authorization:
Status: EVAL MODE
Evaluation Period Remaining: 7 days, 18 hours, 55 minutes, 35 seconds
Export Authorization Key:
Features Authorized:
<none>
Utility:
Status: DISABLED
Data Privacy:
Sending Hostname: yes
Callhome hostname privacy: DISABLED
Smart Licensing hostname privacy: DISABLED
Version privacy: DISABLED
Transport:
Type: Callhome
License Usage
(C9300-48 Network Advantage):
Description:
Count: 1
Version: 1.0
Status: EVAL MODE
Export status: NOT RESTRICTED
(C9300-48 DNA Advantage):
Description:
Count: 1
Version: 1.0
Status: EVAL MODE
Product Information
UDI: PID:C9300-48P,SN:FCW2244E11Y
Agent Version
Smart Agent for Licensing: 4.5.6_rel/12
Component Versions: SA:(1_3_dev)1.0.15, SI:(dev22)1.2.1, CH:(rel5)1.0.3, PK:(dev18)1.0.3
Reservation Info
License reservation: DISABLED
Once a license is registered the next renewal attempt takes place after 6 months thus you need to connect to the CSSM to get license register.
----- snip ------
Registration:
Status: REGISTERED
Smart Account: XXXXXXXXXXX
Virtual Account: XXXXXXXXXXX
Export-Controlled Functionality: Allowed
Initial Registration: SUCCEEDED on Sep 19 12:29:44 2018 CDT
Last Renewal Attempt: None
Next Renewal Attempt: Mar 18 12:29:44 2019 CDT <------------
Registration Expires: Sep 19 12:21:39 2019 CDT
Status: AUTHORIZED on Sep 19 12:31:48 2018 CDT
Last Communication Attempt: SUCCEEDED on Sep 19 12:31:48 2018 CDT
Next Communication Attempt: Oct 19 12:31:47 2018 CDT
Communication Deadline: Dec 18 12:25:46 2018 CDT
Content for Community-Ad
July's Community Spotlight Awards
