SNMP mib flash cache
SR70982
Hey Guys,
I am observing this command (SNMP mib flash cache) is added after upgrading the switch from 15.2(6)E3 to 15.2(7)E2 on Catalyst 2960X-24TD-L
Need to know if there will be any functional impact due to this and whether it is added by default after version upgrade
Previous version its not present.
Help is much appreciated
SR
balaji.bandi
Its only addon option to monitor flash, if you do not need to disable polling that MIB OID.
as such, i do not see ny issue with that, but keep monitor any high process adding after the upgrade? which impact on your network?
BB
