Some NIC's are not working at POE Plus ports -how to create a workaround-
joepena2012
                   Hi community,
we have an issue with some NIC-cards connecting to a new standard switch device.
Switch device is: WS-C4506-E sw. 12.2.53.SG1
Modules:
1     6  Sup 6L-E 10GE (X2), 1000BaseX (SFP)    WS-X45-SUP6L-E
2    48  10/100/1000BaseT Premium POE E Series  WS-X4648-RJ45V+E
3    48  10/100/1000BaseT Premium POE E Series  WS-X4648-RJ45V+E
4    48  10/100/1000BaseT Premium POE E Series  WS-X4648-RJ45V+E
5    48  10/100/1000BaseT Premium POE E Series  WS-X4648-RJ45V+E
6    48  10/100/1000BaseT Premium POE E Series  WS-X4648-RJ45V+E
Problem description:
When some NIC-cards try to connect to one of the switchports on the WS-X4648 Module the Port is not connecting.
When we tried to verify with network tester we have the same issue.
From network tester support we got the feedback that this is caused by the POE Plus standard and will be fixed with next firmware release on the Testers NIC.
However because of various affected NIC cards i would like to run the POE E switchports in "normal" POE operation mode.
Is this possible?
thanks for your feedback
p.mcgowan
Level 3
Level 3
Do you receive any errors on the switch when you connect one of these affected NIC's?
no, nothing on switch site it just looks like no NIC is connecting.
Have you checked the cable layed is cat5 or cat6? Once I faced this kind of issue and found that the problem was with cable lied from the port to switch was cat 5 and ports which are working was layed with cat6 cable.
If it is not the case then please post the error recieved on the switch.
Please provide the output for
sh power inline module (module no)
sh power inline gigabitEthernet 1/10(port)
sh power detail
Please rate the helpful tags
Thanveer
"Everybody is genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is a stupid."
Jepp cable is replaced, and at least devices were connected directly on the switch via different patch cords.
Here the requested output:
NXX#sh power inline module
% Incomplete command.
NXX#sh power inline module 2
Available:3380(w)  Used:139(w)  Remaining:3241(w)
Interface Admin  Oper            Power(Watts)     Device              Class
                            From PS    To Device
Gi2/1     auto   off        0.0        0.0        n/a                 n/a
Gi2/2     auto   off        0.0        0.0        n/a                 n/a
Gi2/3     auto   off        0.0        0.0        n/a                 n/a
Gi2/4     auto   off        0.0        0.0        n/a                 n/a
Gi2/5     auto   off        0.0        0.0        n/a                 n/a
Gi2/6     auto   off        0.0        0.0        n/a                 n/a
Gi2/7     auto   off        0.0        0.0        n/a                 n/a
Gi2/8     auto   off        0.0        0.0        n/a                 n/a
Gi2/9     auto   off        0.0        0.0        n/a                 n/a
Gi2/10    auto   on         16.6       15.4       AIR-LAP1142N-E-K9   3
Gi2/11    auto   off        0.0        0.0        n/a                 n/a
Gi2/12    auto   on         16.6       15.4       Ieee PD             0
Gi2/13    auto   off        0.0        0.0        n/a                 n/a
Gi2/14    auto   off        0.0        0.0        n/a                 n/a
Gi2/15    auto   off        0.0        0.0        n/a                 n/a
Gi2/16    auto   off        0.0        0.0        n/a                 n/a
Gi2/17    auto   off        0.0        0.0        n/a                 n/a
Gi2/18    auto   off        0.0        0.0        n/a                 n/a
Gi2/19    auto   off        0.0        0.0        n/a                 n/a
Gi2/20    auto   off        0.0        0.0        n/a                 n/a
Gi2/21    auto   off        0.0        0.0        n/a                 n/a
Gi2/22    auto   off        0.0        0.0        n/a                 n/a
Gi2/23    auto   off        0.0        0.0        n/a                 n/a
Gi2/24    auto   off        0.0        0.0        n/a                 n/a
Gi2/25    auto   off        0.0        0.0        n/a                 n/a
Gi2/26    auto   off        0.0        0.0        n/a                 n/a
Gi2/27    auto   off        0.0        0.0        n/a                 n/a
Gi2/28    auto   off        0.0        0.0        n/a                 n/a
Gi2/29    off    off        0.0        0.0        n/a                 n/a
Gi2/30    auto   off        0.0        0.0        n/a                 n/a
Gi2/31    auto   off        0.0        0.0        n/a                 n/a
Gi2/32    auto   off        0.0        0.0        n/a                 n/a
Gi2/33    auto   off        0.0        0.0        n/a                 n/a
Gi2/34    auto   off        0.0        0.0        n/a                 n/a
Gi2/35    auto   off        0.0        0.0        n/a                 n/a
Gi2/36    auto   off        0.0        0.0        n/a                 n/a
Gi2/37    auto   off        0.0        0.0        n/a                 n/a
Gi2/38    auto   off        0.0        0.0        n/a                 n/a
Gi2/39    auto   off        0.0        0.0        n/a                 n/a
Gi2/40    auto   off        0.0        0.0        n/a                 n/a
Gi2/41    auto   off        0.0        0.0        n/a                 n/a
Gi2/42    auto   off        0.0        0.0        n/a                 n/a
Gi2/43    auto   off        0.0        0.0        n/a                 n/a
Gi2/44    auto   off        0.0        0.0        n/a                 n/a
Gi2/45    auto   off        0.0        0.0        n/a                 n/a
Gi2/46    auto   off        0.0        0.0        n/a                 n/a
Gi2/47    auto   off        0.0        0.0        n/a                 n/a
Gi2/48    auto   off        0.0        0.0        n/a                 n/a
Totals:          2    on    33.1       30.8
NDEEX051#sh power inline gi2/30
                            From PS    To Device
Interface  AdminPowerMax   AdminConsumption
             (Watts)           (Watts)
Gi2/30                30.0                 15.4
NXX#sh power inline gi2/30
                            From PS    To Device
             (Watts)           (Watts)
Gi2/30                30.0                 15.4
NDEEX051#sh power det
Power                                             Fan      Inline
Supply  Model No          Type       Status       Sensor   Status
PS1     PWR-C45-4200ACV   AC 4200W   good         good     good
PS1-1                         220V   good
PS1-2                         220V   good
PS2     PWR-C45-4200ACV   AC 4200W   good         good     good
PS2-1                         220V   good
PS2-2                         220V   good
Power supplies needed by system    : 1
Power supplies currently available : 2
Power Summary                      Maximum
(in Watts)              Used     Available
System Power (12V)        780        1360
Inline Power (-50V)       139        3380
Backplane Power (3.3V)      0          40
Total                     919 (not to exceed Total Maximum Available = 4200)
Power Measurement    Inline Power (-50V)
(in Watts)             (+/- 50Watts)
PS1                          50
PS2                           0
Total                        50
                             Watts Used of System Power(12V)
Mod   Model                 budgeted instantaneous  peak   out of reset  in reset
1    WS-X45-SUP6L-E           200         125       126       200         200
2    WS-X4648-RJ45V+E          92         --        --         92          10
3    WS-X4648-RJ45V+E          92         --        --         92          10
4    WS-X4648-RJ45V+E          92         --        --         92          10
5    WS-X4648-RJ45V+E          92         --        --         92          10
6    WS-X4648-RJ45V+E          92         --        --         92          10
--   Fan Tray                 120         --        --        --          --
       Total                   780         125       126       660         250
                        Watts used of Chassis Inline Power (-50V)
                        Inline Power Admin  Inline Power Oper
Mod   Model                PS     Device       PS     Device     Efficiency
1    WS-X45-SUP6L-E           -        -          -        -           -
2    WS-X4648-RJ45V+E        33       31         18       16          93
3    WS-X4648-RJ45V+E        66       62         16       15          93
4    WS-X4648-RJ45V+E         0        0          3        3          93
5    WS-X4648-RJ45V+E        33       30         25       23          93
6    WS-X4648-RJ45V+E         8        7          8        7          93
       Total                 140      130         70       64
NXX#
