SPAN by destanation port-channel
Hi I have 3064 Source interface port-channel 6
Now I set destanation port-channel 8
IF set on the port for example channel-group 8 force mode active
Donnot have command switchport monitor
On the port-channel interface also donnot have command switchport-monitor
now if set dest port on interface port-channel 8 monitor sesssion donnot up say to me dst port in wrong mode
show version of switch
Software
BIOS: version 5.0.0
NXOS: version 9.3(10)
BIOS compile time: 06/05/2018
NXOS image file is: bootflash:///nxos.9.3.10.bin
NXOS compile time: 7/8/2022 9:00:00 [07/08/2022 18:10:17]
Hardware
cisco Nexus3000 C3064PQ Chassis
Intel(R) Celeron(R) CPU P4505 @ 1.87GHz with 3901496 kB of memory.
Processor Board ID FOC17366Z65
Device name: Switch-3064-L2-Transit
bootflash: 1874880 kB
usb1: 0 kB (expansion flash)
Kernel uptime is 26 day(s), 16 hour(s), 57 minute(s), 15 second(s)
Last reset at 806005 usecs after Sat Jan 30 13:21:51 2010
Reason: Reset Requested by CLI command reload
System version: 9.3(10)
Service:
plugin
Core Plugin, Ethernet Plugin
Active Package(s):
How can solve this ??
have you got chance to read the post replied above and limitation.
BB
balaji.bandi
Why do you want destination as Port-channel ? what is the use case. And it is  not supported.
Characteristics of Destination Ports
Each local SPAN session must have a destination port (also called a monitoring port) that receives a copy of traffic from the source ports or VLANs. A destination port has these characteristics:
  • Can be any physical port. Source Ethernet and FCoE ports cannot be destination ports.
  • Cannot be a source port.
  • Cannot be a port channel.
  • Does not participate in spanning tree while the SPAN session is active.
  • Is excluded from the source list and is not monitored if it belongs to a source VLAN of any SPAN session.
  • Receives copies of sent and received traffic for all monitored source ports.
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus3000/sw/system_mgmt/7_x/b_Cisco_Nexus_3000_Series_NX-OS_System_Management_Configuration_Guide_7x/b_Cisco_Nexus_3000_Series_NX-OS_System_Management_Configuration_Guide_7x_chapter_010001.ht...
BB
Sure Can you tess on nexus 3064 source port port-channel 1
destanation port port-channel2
If you config port-channel For LACP or other mode
For example ethernet 1/1
channel-group 1 force mode active
and ethernet 1/2
You want copy taffic port-channle 1 to port-channel 2
have not command swtich port monitor on port-channel config
BB
