SPAN on NEXUS 5000
mriemer
I need to configure a SPAN monitor session on a N5K. Attached are two FEX 2148.
4 interfaces on the FEX should be source ports with both traffic directions (rx and tx) to monitor.
When I try to configure more then two Interfaces as source, I got the following error:
ERROR: Ethx/x/xxx: Only 2 tx SPAN sources allowed per system. NOTE: Default dir
ection is both
Anyone an idea?
Thank you!
Marc
Thats a limitation if you read SPAN config guide. But I think with later codes you may be able to add more thought i have not checked it.
Hope this helps
*****Please rate useful posts*******
Madhu.
Hope this helps
Madhu.
