SPAN sessions in 3750G
conectividade
Beginner
Beginner
Hi, folks!
I would like your help!
We would like to do rspan from 3750G-SI to 2950G-EI or 2960-SI, that works?
Because we need more than two sessions of span, so,
We though to conect by trunk a 3750 stack to 2950G and connect the
all equipment that will receive the traffics, and preserve
the other session of 3750G.
we accept other suggestions.
thanks,
Renato
Yongbing WU
Beginner
Beginner
Trunk is ok to support multi vlans, including the vlan used by rspan.
Hope this helps.
skambham
I Think it is Possible. Can u send the network topology.
Sumakanth
Messrs,
here is!
where S1=server1, S2=server2...
thank you,
Renato
Messrs,
so, we can to do it, with
this switches (3750 and 2950)?
thanks,
Renato
Recognize Your Peers
