elias.pereira
Beginner
Spanning tree mode on C3750 compatible with SG300?
Hello everyone,
In our computer park we have two C3750 in stack. The rest of the switches are Cisco SG300-28P.
Which way should I set for it to be compatible in both models and the C3750 model be the root?
1 ACCEPTED SOLUTION
Try to configure instance 1
on 3750
spanning-tree mst configuration
name mymst
revision 1
instance 1 vlan 1-4096  [ use question mark if hyphen is not accepted]
spanning-tree mst 1 priority 4096
on sg300
name mymst
revision 1
spanning-tree mst 1 priority 61440
Masoud
7 REPLIES 7
Masoud Pourshabanian
Collaborator
edited
SG300-28P supports RSTP and MSTP. The default is RSTP. Check the link below.
http://www.cisco.com/c/en/us/products/collateral/switches/small-business-smart-switches/data_sheet_c78-610061.pdf
http://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/sf30x_sg30x/administration_guide/CLI_Nikola300_1_3_7.pdf
3750 supports PVST MST Rapid PVST. The default is Rapid PVST.
on 3750
spanning-tree mode mst
Spanning-tree mst 0 priority 4096
On others
Spanning-tree mst 0 priority 61440
Hope it helps,
Masoud
Hello Masoud,
Why you edited the post?
I checked 3750 and noticed RSTP is not in the command sets so I edited my post. What you see you now will work on both 3750 on SG300.
Hope it helps,
Masoud
Masoud,
In sg300 no have instance 0 on the command: Spanning-tree mst 0 priority 61440
#spanning-tree mst
configuration Configure MSTP parameters
<1-7> Specify instance ID
max-hops Configure the maximum hops allowed in a region for a
Spanning Tree.
edited:
I try to set on 3750: "spanning-tree mst 1 priority 4096", but the priority always stay 32768 and when I set "spanning-tree mst 0 priority 4096" the priority stays 4096
on 3750
name mymst
revision 1
on sg300
name mymst
revision 1
Masoud
Hello Masoud,
I set up that way and works very fine!!
Thanks for your help! Really thanks!
You are most welcome. Happy to help.
Masoud
