Spanning tree Portfast Issue
NitinPowar99674
Dear Experts,
We have a catalyst 9200 switch and a bare metal server connected on it. We have configured the spanning-tree portfast on a port. For the last 3-4 months it's been working fine but firm last week it's not performing well. interface protocol and state are up, but we cannot ping the server but switch to learn the MAC address of the server.
After wiping out spanning-tree portfast cmd, we could ping the server.
Need your assistance on why it's happened.
note: we have another a bare metal server that is connected on the same switch and port configured in spanning-tree portfast
8 Replies 8
balaji.bandi
have done any patching on the Server ? what logs you see on the Switch ?
I do not believe this is issue with spanning tree here (hgih level as per the information)
Put the config back and test with other device see if that works ?
BB
Thanks for your reply
For 1st question
It does not specify any related issue. It's showing only changed
configuration, manually shut, and no shut interface.
But I will try using another device.
Also post the configm what device and IOS code running, if you looking forther help here.
BB
@MHM Cisco World .??
I correct my answer below.
don't worry no more FOLLOW word
LOL
@MHM Cisco World Ok  , but I already explained to you what the correct way to FOLLOW is -> ?
 M.
https://www.cisco.com/c/en/us/support/docs/ios-nx-os-software/nx-os-software/213906-nexus-9000-mac-move-troubleshooting-and.html
Issue and Solution.
the Server is face mac move and make NSK not learn it MAC any more.
check Server side.
