spanning tree vlan not showing complete interface
Question
i have a problem.
i have configured spanning tree on my 2 L3 switches but i don't see the interface per vlan . i only see one interface instead of seeing all the interfaces connected to the switch. There is a photo attached to explain better
7 Replies 7
balaji.bandi
post below output : (not screenshot attachments)
show spanning-tree active
show spanning-tree detail
show spanning-tree brief
show spanning-tree summary
BB
I have attached it as pdf.
Thank you for the output -
what you mean by this, end device connected to switch port ?
BB
Jon Marshall
You will only see the ports in spanning tree output if the ports are up.
Jon
can we see topology ?
Hello
Just like to add there would be only 1 stp instance per port channel, is this what you mean?
Kind Regards
Paul
Yes that is what I mean
