08-31-2010 10:42 AM - edited 03-06-2019 12:45 PM
My customer has a CATOS 6500 series switch with the command "set spantree priority 2000"
How does this value relates to a value i.e. 4096 in IOS?
I need to connect with a IOS box to a CATOS switch network an worry about faulty spanning tree value's to use.
08-31-2010 11:05 AM
It relates the same ie. the values are directly compatible so the CatOS swith in this instance would take priority.
Jon
08-31-2010 11:13 AM
Ok Jon Thank you very much
