12-18-2013 06:09 AM - edited 03-07-2019 05:08 PM
Hi everybody,
I'm sorry about my poor english... I'm French (but it is not contagious)
I need your help (or TAC Help ) about speed and duplex problems.
My network :
[C2960G-24TC-L with sfp GLC-FE-100LX on Gig 0/23] <--> (Singlemode Fiber 9/125µ) <--> [Cisco SF200-24 with sfp MFELX1 on Gi1]
Autonegociation everywhere...
My problem :
%CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet0/23 (not full duplex), with f02929f97095 gi1 (full duplex).
- I can't force speed/duplex on MFELX1 (actually a-full a-100)
- I can't force speed/duplex on GLC-FE-100LX (actually a-half a-100)
Is there an incompatibility between this equipements ?
Configuration detail :
WS-C2960G-24TC-L 12.2(58)SE2 C2960-LANBASEK9-M
Cisco SF200-24 Firmware Version (Active Image): 1.2.9.44
#sh int gig 0/23 capabilities
GigabitEthernet0/23
Model: WS-C2960G-24TC-L
Type: 100BaseLX-FE SFP
Speed: 100
Duplex: half,full
Trunk encap. type: 802.1Q
Trunk mode: on,off,desirable,nonegotiate
Channel: yes
Broadcast suppression: percentage(0-100)
Flowcontrol: rx-(off,on,desired),tx-(none)
Fast Start: yes
QoS scheduling: rx-(not configurable on per port basis),
tx-(4q3t) (3t: Two configurable values and one fixed.)
CoS rewrite: yes
ToS rewrite: yes
UDLD: yes
Inline power: no
SPAN: source/destination
PortSecure: yes
Dot1x: yes
Multiple Media Types: rj45, sfp, auto-select
#show int gigabitEthernet 0/23 transceiver properties
Diagnostic Monitoring is not implemented.
Administrative Speed: auto
Administrative Duplex: auto
Administrative Auto-MDIX: on
Administrative Power Inline: N/A
Operational Speed: 100
Operational Duplex: half
Operational Auto-MDIX: on
Media Type: 100BaseLX-FE SFP
Configured Media: auto-select
Active Media: sfp
Thank you so much for yor help !
12-18-2013 02:35 PM
Disable interface CDP on both uplinks.
12-18-2013 11:59 PM
Thank you Leo,
It doesn't work, but I found an solution !
A strange solution...
I forced the C2960G-24TC-L to work with SFP :
media-type sfp
When I do that, I have the possibility to force the duplex (but not the speed... ok why not... ) :
duplex full
It is not very clean but my link is up and full-100 both sides.
Not very clean because :
C2960 side = force duplex, auto speed
SF200 side = auto duplex, auto speed
No errors... the link is clean.
Anyone known the reason or a better solution ?
