split port 4 ways error
robertkwild
hi all,
trying to split a qsfp port 4 ways but i get the following error
module-type qsfp-split-4 force
% bad split mode, please select 'qsfp-split-2'
thanks,
rob
Mark Elsen
      - On which hardware model   , and software version are you getting this error ?
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
its a mellanox switch but uses the same syntax as cisco
 - Yet  , not a cisco device  problem, consider contacting mellanox support or search for user forum with searching powers of the Net.
 M.
       Beauty and terror
      Just keep going
       No feeling is final
I used another interface and that let me split it 4 ways
I noticed when I did a "sh int status" it was just even interfaces it was showing, so looks like for every split it uses up 2 interfaces, so the next one, I will miss the next int and slot it in the 2nd one and it works, bit wierd
