SRW2008P not putting out any power?
Have a new SRW2008P.  I can connect to the web interface just fine, and it switches packets without any problems.  Web interface says POE is enabled on all 8 ports, but "Mode" is "off" for all eight ports.  If I plug in a Polycom IP501 phone I get nada.  A voltmeter across pins 4 and 8 is zero volts.  Is the POE circuitry in this switch fried?  Or am I missing a setting to turn it on?
Cheers,
Jeff LaCoursiere
SunFone
bradmusgrove
Your post is quite old but the answer which you may likely already know is the
SRW2008P puts out voltage across the data pairs DC+ PINS 1,2  DC- PINS 3,6 using the 802.3af alternative A
http://pinouts.ru/Net/poe_pinout.shtml
