SSH Problem
aliahmadi1177
Frequent Visitor
Frequent Visitor
Hello
We recently bought a 3750G-24TS-S (refurbished) switch and got into trouble to set the SSH on it. The problem arises when the configuration is finished. Everything is working properly and, before exiting the Express Setup, I connected to the switch using SSH and logged in successfully with the password I had entered in configuration. After adding the following few lines to the configuration, I lost the local connection and only had SSH permission from VLAN 99 over port 24:
sw-1(config)#int gi 1/0/24
sw-1(config-if)#switchport mode access
sw-1(config-if)#switchport access vlan 99
So I connected to the address 192.168.1.139 with the Putty program, and I logged in by entering the username password, I entered the "wr" or "copy running-config startup-config" command and closed the Putty SSH session, but unfortunately the next time I wanted to connect with the Putty SSH, it showed me "Access Denied" message after entering username and password however I can ping(CMD) and even reach the switch by putty but It looks like my switch is on the Alzheimer's username password.
* PC is connected to switch with a CAT6 cable.
* PC is connected to port 24 and IP has been defined statically : 192.168.1.114 /24  -  Gateway : 192.168.1.139
* A TP-link home router modem is connected to the switch (192.168.1.1 /24).
* CMD Ping and Putty "Access Denied" is attached to this post.
I will put run command's output before and after the config and the configuration command I had entered :
run before config :
Current configuration : 1734 bytes
version 12.2
no service pad
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
switch 1 provision ws-c3750g-24ts-1u
system mtu routing 1500
ip subnet-zero
ip dhcp pool 10.0.0.0
network 10.0.0.0 255.255.255.0
lease 0 0 10
spanning-tree mode pvst
spanning-tree portfast default
vlan internal allocation policy ascending
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface Vlan1
ip address 10.0.0.1 255.255.255.0 secondary
ip address 10.0.0.3 255.255.255.0
ip classless
ip http server
ip http secure-server
control-plane
line con 0
line vty 0 4
privilege level 15
no login
line vty 5 15
privilege level 15
no login
end
Configuration commands :
> conf t
switch(config)# hostname sw-1
sw-1(config)# ip domain-name test.com
sw-1(config)# crypto key generate rsa
2048
sw-1(config)# username test privilege 15 secret 1234
sw-1(config)# line vty 0 15
sw-1(config-line)# login local
sw-1(config-line)# transport input ssh
sw-1(config)# access-list 1 permit 192.168.1.0 0.0.0.255
sw-1(config-line)# access-class 1 in
sw-1(config)#ip ssh version 2
sw-1(config)#vlan 99
sw-1(config-vlan)#name MGT
sw-1(config)#int vlan 99
sw-1(config-if)#ip address 192.168.1.139 255.255.255.0
sw-1(config-if)#no shut
------"run after config" part is placed before entering 3 following lines, because the switch will be cut off-------
run after config :
Current configuration : 2026 bytes
version 12.2
no service pad
hostname sw-1
boot-start-marker
boot-end-marker
username test privilege 15 secret 5 $1$MPpr$p2Wx3zamweRVpBK6aaNHz/
no aaa new-model
ip subnet-zero
lease 0 0 10
ip ssh version 2
interface Vlan1
interface Vlan99
ip classless
ip http server
control-plane
line con 0
line vty 0 4
access-class 1 in
privilege level 15
login local
transport input ssh
line vty 5 15
access-class 1 in
privilege level 15
login local
transport input ssh
end
15 Replies 15
Thanks for the update. Glad to know that you found and fixed the problem.
Rick
