Hi to all, i've to put 7 2960-x switch in single stack, but i've only 50 cm. stack cable.
I know shold be best have a 3 mt cable to close the stack, but the customer didn't bought it.
I know i can make an-half stack, without closing the ring and i've seen an example how to stack 4 switch with 50 cm cable:
anyone can suggest how to stack 7 switch with 50 cm cable ?
any help or suggestion appreciated
It could be done like this:
But you should also think about splitting it into two stacks with four and three switches. The more switches are in a stack, the more sluggish gets the cli very often.
Hi Karsten,
Thanks a lot for your answer.
I my drawing, based on ours, correct?
There is any rules to make these connections, or it's free (connection 1 can be connected with connection 1 or 2 of the other unit)?
Thanks in advance for your answer.
The main rule is that in the end, you should have a closed ring through all your switches in the stack.
Hi Karsten,
If I understand well, if we can take any way as we close the ring it's OK.
Thanks a lot, I finally understood
