Stacking 2960S switches options
Phuong Trinh
I have 2  Catalyst 2960S (24 ports and 48 ports). Can I stack them using the Uplink connection instead of the stack modules. I know Stack module is the best option but it is kind of expensives (half price of the 24 ports switch) and I only need to stack no more then 2 switches.
Phuong
2 Accepted Solutions
Giuseppe Larosa
Hello Phuong,
no you cannot use uplink to build a stack, stacking requires stacking modules and flexstack cables.
using the uplink ports you can only create a cluster that is only for administrative purposes
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_58_se/configuration/guide/swclus.html
A switch stack is different from a
switch cluster
.  A switch cluster is a set of switches connected through their LAN  ports, such as the 10/100/1000 ports. For more information about how  switch stacks differ from switch clusters, see the "Planning and  Creating Clusters" chapter in the
Getting Started with Cisco Network Assistant
on Cisco.com.
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_58_se/configuration/guide/swstack.html
Hope to help
Giuseppe
AhmedSonba
Hello Phuong
You can do it by using FlexStack In order for the switches to stack, a  separate FlexStack module must be  inserted in the rear of the switch.  Without this module, FlexStack  cannot function.
Please refer to the following link for more information
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/white_paper_c11-578928.html
Hope it will help
Ahmed Sonba
Giuseppe Larosa
Hello Phuong,
see
switch cluster
on Cisco.com.
see
Hope to help
Giuseppe
AhmedSonba
Hello Phuong
Hope it will help
Ahmed Sonba
OK, got the message, I will get the stack modules. Thanks for all of the responses.
-Phuong
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Considering the expense of the stack modules, you might want to carefully consider if the features provided by stacking are worth their cost for your usage.  For just a stack of two, a multi gig Etherchannel might satisfy your needs.
