04-25-2017 06:53 AM - edited 03-08-2019 10:19 AM
Can I stack a 3750 48-port switch with a 3750 24-port switch as long as the IOS version is similar?
04-25-2017 06:55 AM
Yes you can make sure they match not only similar , the major and minor numbers in the ios code need to match to get the full feature set between them when stacked , if they don't match fully you will end up with certain features not fully working
04-25-2017 07:00 AM
Great, I will confirm the specifics as you stated. Thank you!
