Stacking 9300
RakaNRpG00
Hello Folks,
Well, I staked 2 9300 switches then I turned on the switches, but when I connected to the switch with a console cable my terminal covered with these interface link state messages, it keeps popping up. Then I decided to remove the stacking cable but these messages stile keeping popping up. Then I did erase start up and /all nvram and these messages keeps popping up, I went to the back of the switch to reset it, also these messages keeps popping up. What should I do???
Both switches are in the same version.
WhatsApp Image 2022-07-01 at 3.04.26 PM.jpegWhatsApp Image 2022-07-01 at 3.18.20 PM.jpeg
balaji.bandi
what is the version of code running both, you need to follow some steps to make the stack working.
1. make sure you have uniq switch number
2. different priority.
follow below guide:
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9300-series-switches/white-paper-c11-741468.html
Note : your screenshot not indicated what is the problem, it is hard to ready ( post console total output in text file to read correctly)
BB
WhatsApp Image 2022-07-01 at 3.35.59 PM.jpegOK But Why these messages keeps popping up ? I can't run any commands.
break the stack and read the document and start over again bulding the stack
Note : as i mentioned the pictures not give any information other than how you connected, post the boot logs and configuration to help better.
BB
