We just received some Catalyst 9300 switches with StackWise-320 cables. The ports on the switch have a screw hole in the top center above the port. The cables fit into the port just fine and have a spring adapter/fitting that fits into nothing in the port; the stacking cables just hang there loose and would fall out easily.
Is there an adapter we can buy to make that fit?
Nothing in the literature or the interwebs match this configuration.
I have no photos...sorry.
Thanks in advance.
DC
