faze1sari
Beginner
Stacking Issue with WS-C3750X-48T-S and WS-C3750E-24PD
I am having an issue stacking an existing 3750e POE switch with a 3750x stack, the POE switch keeps coming up with version mismatch.
GFM-STACK#sh switch
Switch/Stack Mac Address : a493.4cf7.4080
                                           H/W   Current
Switch#  Role   Mac Address     Priority Version  State
*1       Master a493.4cf7.4080     15     1       Ready
2       Member a493.4cf2.3780     1      1       Ready
3       Member a493.4cc0.da00     1      1       Ready
4       Member 0817.35e7.b800     1      1       Version Mismatch
GFM-STACK#       dir
Directory of flash:/
    2  drwx         512  Feb 28 1993 19:19:57 -05:00  update
    6  -rwx        1096  Sep 26 2013 20:51:58 -04:00  vlan.dat
    7  -rwx        3096  Sep 27 2013 09:20:08 -04:00  multiple-fs
    8  -rwx        3855  Sep 27 2013 09:20:08 -04:00  private-config.text
    9  -rwx       21837  Sep 27 2013 09:20:08 -04:00  config.text
   10  drwx         512  Feb 28 1993 19:09:17 -05:00  c3750e-universalk9-mz.122-55.SE3
GFM-STACK#sh lic feature
Feature name             Enforcement  Evaluation  Clear Allowed  Enabled
ipservices               yes          yes         yes            yes
ipbase                   yes          no          yes            no
lanbase                  no           no          yes            no
POE switch
WP-GFM-PSW1-N#dir
    2  -rwx         736  Sep 27 2013 09:24:51 -04:00  vlan.dat
    3  -rwx        1937  Sep 27 2013 10:07:43 -04:00  private-config.text
    4  -rwx        6975  Sep 27 2013 10:07:43 -04:00  config.text
  428  -rwx    14587929  Sep 26 2013 14:11:18 -04:00  c3750e-universalk9-mz.122-55.SE3.bin
  429  -rwx        4120  Sep 27 2013 10:07:44 -04:00  multiple-fs
WP-GFM-PSW1-N#sh lic feature
advipservices            yes          no          yes            no
ipservices               yes          yes         yes            no
ipbase                   no           no          yes            yes
11 REPLIES 11
Reza Sharifi
Hall of Fame Expert
From show license for the POE switches, it appears you have IP Base license and not IP Services. Upgrade the POE switch to IP services and test again.
I have run the same setup in lab with similar equipment and it stacks fine even with a base license and an ip services license so I dont think this is a license issue.
It is booting the same image as the 3750X.
Leo Laohoo
VIP Community Legend
I agree with Reza.
GFM-STACK has IP Services enabled while WP-GFM-PSW1 has IP Base enabled.
Another thing ... Why does "WP-GFM-PSW1" have a host name????  If you want "WP-GFM-PSW1" to join the stack then this switch should NOT HAVE any config.
I recreated the setup in the lab and it worked I had configs on both devices and the same licenses and it stacked without issue. Here are the results:
WP-GFM-STACK#sh ver
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 12.2(55)SE3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 05-May-11 15:40 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x02800000
ROM: Bootstrap program is C3750E boot loader
BOOTLDR: C3750E Boot Loader (C3750X-HBOOT-M) Version 12.2(53r)SE2, RELEASE SOFTWARE (fc1)
WP-GFM-STACK uptime is 4 minutes
System image file is "flash:/c3750e-universalk9-mz.122-55.SE3/c3750e-universalk9-mz.122-55.SE3.bin"
--More--         agree to comply with applicable laws and regulations. If you are unable
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: ipservices
License Type: Permanent
Next reload license Level: ipservices
cisco WS-C3750X-48 (PowerPC405) processor (revision A0) with 262144K bytes of memory.
Processor board ID #############
Last reset from power-on
1 Virtual Ethernet interface
1 FastEthernet interface
80 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
Base ethernet MAC Address       : A4:93:4C:F6:22:00
Motherboard assembly number     : #######
Motherboard serial number       : ###########
Model revision number           : A0
Motherboard revision number     : C0
Model number                    : WS-C3750X-48T-S
Daughterboard assembly number   :##########
Daughterboard serial number     : #########
System serial number            : ########
Top Assembly Part Number        : ###########
Top Assembly Revision Number    : E0
Version ID                      : V02
CLEI Code Number                : COMJT0
Hardware Board Revision Number  : 0x03
Switch Ports Model              SW Version            SW Image
*    1 54    WS-C3750X-48       12.2(55)SE3           C3750E-UNIVERSALK9-M
     2 30    WS-C3750E-24PD     12.2(55)SE3           C3750E-UNIVERSALK9-M
--More--         Switch 02
Switch Uptime                   : 5 minutes
Base ethernet MAC Address       : B4:14:89:34:A5:00
Motherboard assembly number     : 73-11176-14
Model revision number           : L0
Motherboard revision number     : B0
Model number                    : WS-C3750E-24PD-S
Daughterboard assembly number   : 800-29
System serial number            : ###########
Top assembly part number        : 800-289
Top assembly revision number    : B0
Version ID                      : V04
CLEI Code Number                : COMCE0
License Level                   : ipbase
License Type                    : Permanent
Next reboot licensing Level     : ipbase
Configuration register is 0xF
WP-GFM-STACK#sh switch
Switch/Stack Mac Address : a493.4cf6.2200
                                           H/W   Current
*1       Master a493.4cf6.2200     15     1       Ready
2       Member b414.8934.a500     1      1       Ready
Leo Laohoo
No it's not.  The stack master has IP Services and the slave has IP Base.
Ok, now you've got stacking with two different Feature Sets working.  Fine.  Now do configure Layer 3 stuff on the stack master.  Once you've done, kill the power to the stack master.  See what happens to your slave running IP Base Feature Set license.  Pay close attention to your configuration.
Same licenses meant running same licenses in lab as the switches I am trying to stack in production.
As Leo said, even though it can work fine, but it is not a good idea to have different types of licenses in a stack.  If for example, the master switch is the one with IP Services license and you are using PBR (which is only supported in IP Services) fails, you will lose you PBR config since the second switch with IP base license does not support PBR. Now, if the business does not want to pay the extra cost for the license, all you have to do is to make them aware of what can happen and document it, so they don't call you at midnight when the master switch goes down.
Thanks for the info but that's not anything I am worrying about there are 4 other switches in the stack running ip services also we were actually given something we dont need as we dont use any of the feature sets in ip services its strictly a layer 2 switch. My question is should this stack correctly?
Partha Dasgupta
I believe  we verified  the show version and confirmed  the boot statement in the POE switch.
Partha
See my reply above
