StackWise Virtual on C9500-32C
passakorn.m
can we use just 2 interfaces for StackWise Virtual ?
one interface for StackWise Virtual link
and one interface for Dual active detection link.
or any advise to reduce wasteful of using interface for StackWise Virtual .
Reza Sharifi
Yes, you can just use one link. The reason for 2 is redundancy but if you think you don't need it, than you can just use one link for each.
Reza Sharifi
