Static MAC entries
A really quick simple one guys...
When would you statically enter a MAC into the MAC-address-table, does this just relate to setting a mac to a port in switchport security?
Kallol Bosu
When you configure a port with port-security /Dot1X, the mac address learned on the port will always be shown as "STATIC" even though it is not hardcoded by Administrator.
As Joseph correctly mentioned, there are many other reasons for putting a static MAC on box. Let me give you few classic examples-
1. Microsoft NLB MAC address (unicast IP to multicast MAC mapping, not processed by hardware by default), so we configure static ARP/MAC binding for the same.
2. Cobranet multicast traffic (L2)-  Cobranet multicast MAC does not use standard multicast MAC range so they are being treated as broadcast. When a switch (that has an SVI for that Vlan) receives that traffic, it gets punted to CPU and causes high CPU.
We can put a static MAC for Cobranet Multicast mac to avoid this issue.
3. if you need to drop a MAC statically for any reason then that can be done by static mapping-
either you can point that to an interface (which is down/down) or use "drop" keyword to drop that MAC directly (not supported on all platforms).
Please rate this post if helpful.
Kallol
Reza Sharifi
Setting static mac in switchport security is one option. I have also seen some cameras or card readers that require static mac address.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
No, there are other reasons such as the target host never transmits traffic, so as switch would always flood traffic to its MAC unless you hard code the MAC as a static.
Kallol Bosu
Kallol
