Static routes on RV345P
ferdinando.alde
On an RV345P the firewall blocks the return from static routes, on an RV320 it works perfectly. I have a route from 192.168.12.x to 192.168.132.0 with gateway 192.168.12.12. The ping returns well and the route is perfect, but it does not return the content.
I finished the ideas !!!
Hi @ferdinando.alde
Long shot here without config but icmp and other protocols like tcp and udp may have different behavior on firewall and routing. Icmp permit even asymmetric routing whilst other protocol does not.
-If I helped you somehow, please, rate it as useful.-
