04-13-2012 10:02 PM - edited 03-07-2019 06:07 AM
Hi everybody.
Backbonefast eliminates max -age times( default is 20 sec),while uplinkfast eliminates listening and learning times( default is 30 sec).
If we have an access switch as
rest of switched network-----------f1/1 blockedport SW f1/1 Rootport-------------------rootswitch
Let say our network is configured with backbonefast feature and we enable uplinkfast on sw1,;sw1 receives an inferior bpdu on its blocked port ,will sw1 instantly transition the f1/1 to forwarding states because backbonefast eliminates max age timer and uplinkfast eliminates listening and learning times ?
thanks and have a great weekend
Solved! Go to Solution.
04-14-2012 08:46 AM
Hello Sarah,
Unable to understand your topology exactly. Please provide an appropriate topology & will work on it further.
Vivek
04-14-2012 09:26 AM
Hi Sarah,
Since Backbone fast covers a wider range of switches and it can detect a link that is not directly connected to the local switch, the convergence can take up to 50 seconds. Backbone fast reduces 50 to 20 seconds. Uplink fast reduces the convergence time from 30 seconds to about 14 seconds. Keep in mined that Backbone fast and uplink fast were design to speed the convergence before RSTP (802.1w) was released. 802.1w already had these capacities and no need for these protocols.
Here are a couple good doc for reference:
http://www.cisco.com/en/US/tech/tk389/tk621/technologies_tech_note09186a0080094641.shtml
http://www.cisco.com/en/US/tech/tk389/tk621/technologies_tech_note09186a00800c2548.shtml
Have a nice weekend
04-14-2012 11:04 AM
Hello Sarah,
Yes they are.
From the second link Reza provided (http://www.cisco.com/en/US/tech/tk389/tk621/technologies_tech_note09186a00800c2548.shtml) it corresponds to the RLQ PDU format that you have captured.
Moreover PID 0x0108 (RLQ Request) and 0x0109 (RLQ reply) that we can see in your capture correspond to one of those Cisco Protocol IDs for SNAP encapsulated data.
RLQ SNAP PIDs are not listed on the link below :
But they are at the last slide of :
http://www.michaelanderson.ca/12W-NET3011-010/Wk03-Reference-EthernetFrames.pdf
Regards.
Karim
04-14-2012 08:46 AM
Hello Sarah,
Vivek
04-14-2012 10:15 AM
Thanks Vivek .
Please disregard my question because it is not possible. Let me elaborate on it.
Suppose we have an access switch configured with uplinkfast and backbonefast features with one blockedport and one root port.
If this access switch receives a inferior bpdu on its blocked port, Will such port be put in forarding state rightaway? ( backbonefast eliminates max-age time and uplinkfast eliminates times in listening and learning states?
I just realised it is not possible because backbonefast feature kicks in when a switch receives inferior bpdu and uplinkfast kicks in when superior bpdu is received. Since in our example above switch receives an inferior bpdu so backbone feature kicks in and eliminates 20 sec . But switch still put its blocked port through listening and learning states.Uplink feature though configured on switch does not kick in because switch did not receive a superior bpdu.
Have a great weekend.
04-14-2012 09:26 AM
Hi Sarah,
Have a nice weekend
04-14-2012 10:06 AM
Thanks Reza
With regard to Backbonefast, Does RLQ request look like as:
o. Time Source Destination Protocol Length Info
123 226.204000 c0:02:0f:d8:f1:05 Spanning-tree-(for-bridges)_00 LLC 60 U, func=UI; SNAP, OUI 0x00000C (Cisco), PID 0x0108
Frame 123: 60 bytes on wire (480 bits), 60 bytes captured (480 bits)
IEEE 802.3 Ethernet
Destination: Spanning-tree-(for-bridges)_00 (01:80:c2:00:00:00)
Source: c0:02:0f:d8:f1:05 (c0:02:0f:d8:f1:05)
Length: 43
Trailer: 000000
Logical-Link Control
Data (35 bytes)
0000 00 00 00 00 00 80 00 c0 00 0f d8 00 00 00 00 00 ................
0010 13 80 00 c0 02 0f d8 00 00 80 2e 02 00 14 00 02 ................
0020 00 0f 00 ...
Does RLQ reply look like as:
124 226.266000 c0:00:0f:d8:f1:03 Spanning-tree-(for-bridges)_00 LLC 60 U, func=UI; SNAP, OUI 0x00000C (Cisco), PID 0x0109
Frame 124: 60 bytes on wire (480 bits), 60 bytes captured (480 bits)
IEEE 802.3 Ethernet
Source: c0:00:0f:d8:f1:03 (c0:00:0f:d8:f1:03)
Length: 43
Trailer: 000000
Data (35 bytes)
0010 00 80 00 c0 02 0f d8 00 00 80 2c 00 00 14 00 02 ..........,.....
0020 00 0f 00 ...
Thanks for the links.
04-14-2012 11:04 AM
Hello Sarah,
Yes they are.
Regards.
Karim
