STP Convergence/Topology Changes
mmelbourne
Level 5
Level 5
We are getting some reports of network 'blips'. The only correlation is a STP topology change in the VLAN on the distribution switches. "show spanning-tree vlan <X> detail" shows the port this came from, but following this port to its attached access layer switch suggests the notification came from the distribution switch (back across the same link). Has anyone seen anything similar? Is there any other way to try and track this down?
Ian Jay
Its most likely the downstream switch is originating the TCN and then a corresponding configuration BPDU is received. Unfortunately there's nothing on the originating switch to tell you it has generated the TCN. This is where detective work comes into play.
Logging messages of interest:
  - network port flapping
  - root bridge changing
  - native vlan mismatch
  - mac address flapping
Spanning tree output:
  - interfaces in "Shr" status
  - interfaces in Bound status
Interface output:
  - CRC or input errors
  - half duplex status
  - output drops
Similar symptoms can also result from switches sending latent BPDUs. This can cause momentary root bridge changes as BPDU updates are not received in time. Depending on the number of vlans you can enable BPDU debugging to narrow a possible timing issue down
