STP portfast
sivam siva
Level 3
Level 3
I read that if portfast port receives a BPDU port will lose its portfast feature.
But in my below test port  keeps  porfast even if it receives a BPDU,
Siva
2 Accepted Solutions
Giuseppe Larosa
Hello Siva,
you have STP portfast enabled on the root port connecting to another switch.
The exact behaviour depends on how you have configured spanning-tree portfast
global mode
spanning-tree portfast default
vs. interface mode
int  gi0/1
spanning-tree portfast enable
One of the two configurations (the first one I suppose) should react changing the port to standard the second one should keep the port in STP portfast mode.
Hope to help
Giuseppe
luis_cordova
Hi @sivam siva ,
Review this discussion:
https://learningnetwork.cisco.com/message/153796#153796
I think it is very informative.
Giuseppe Larosa
Hello Siva,
global mode
vs. interface mode
int  gi0/1
Hope to help
Giuseppe
luis_cordova
Hi @sivam siva ,
