STP problem
d.navetto
Hey guy! I need some help for my network LAN.
I have configurated some switch ( catalyst 3560 )access with the Fastethernet in access for Vlan 360. This Device is trunked with a Core ( caltalyst 6509)  layer, trunked itself with another distribution layer for the server farm ( caltalyst 6513). the VLan is native on the Cat 6513 who is its root spanning tree and it is forwarded trough the entire lan to the access switch. The client gets the IP address but it can't ping its gateway and it is totally out of the network.This Vlan is a Management Vlan and also the server have the same subnet. All the servers are ok and totally reachable by any another vlans. Btw if i put a client directly both on the core or the distribution layer it works perfectly.
Any suggestion ?
20 Replies 20
thanks to all ! i noticed that the link between 6509 and 6513 Master are in that state !!
Sorry i have a question.... but if the po2 on the 6059 is Root spanning tree port for vlan 360 should be in trunk forwarding... it's correct ?
watch this
6509#sh spanning-tree vlan 360 root
                                        Root Hello Max Fwd
Vlan                   Root ID          Cost  Time Age Dly  Root Port
VLAN0360          8552 0024.c480.1a40         1    2   20  15  Po2
6509#sh int po2 trunk
Port                Mode         Encapsulation  Status        Native vlan
Po2                 on           802.1q         trunking      1
Port                Vlans allowed on trunk
Po2                 1-4094
Port                Vlans allowed and active in management domain
Po2                 1-2,8-9,11,18,22,26,30,44-45,50,90,101,200,222-223,225,227,231,234,250-263,268-270,301-352,358-360,363-364,368,371-374,389-390,468,476,492,499-500,554-559,729,900-902
Port                Vlans in spanning tree forwarding state and not pruned
Po2                 1-2,390
(Root For Vlan 360 )6513#sh spanning-tree vlan 360 root
                                        Root Hello Max Fwd
VLAN0360          8552 0024.c480.1a40         0    2   20  15
6513#sh int po2 tru
Po2                 1-4094
Po2                 1-2,8,10-11,16,18,22,26,44-45,90,101,200,222-223,225,227,231,234,301-349,352-360,363-399,460-468,499,550-554,700,900-901
Po2                 1-2,8,10-11,16,18,22,26,44-45,90,101,200,222-223,225,227,231,234,301-349,352-360,363-389,391-399,460-468,499,550-554,700,900-901
David,
this could be a possible stp issue, it my also mean we could manipulate the stp path to resolve this, Can you post the relevant output from the show commands requested above.
res
Paul
Please don't forget to rate this post if it has been helpful.
Kind Regards
Paul
On 6509 ..
sh standby brief
                     P indicates configured to preempt.
Interface   Grp  Pri P State   Active          Standby         Virtual IP
Vl9         102  100   Init    unknown         unknown         172.18.248.254
Vl101       100  110 P Active  local           172.21.0.3      172.21.0.1
Vl200       200  110 P Active  local           172.21.200.3    172.21.200.1
Vl231       1    100 P Standby 172.18.242.2    local           172.18.242.1
Vl234       234  110 P Active  local           10.81.1.3       10.81.1.1
Vl250       250  110 P Active  local           172.21.222.3    172.21.222.1
Vl251       251  110 P Active  local           172.21.201.3    172.21.201.1
Vl252       52   100 P Standby 172.21.201.131  local           172.21.201.129
Vl253       202  100 P Standby 172.21.202.3    local           172.21.202.1
Vl254       203  110 P Active  local           172.21.204.3    172.21.204.1
Vl255       204  110 P Active  local           172.21.206.3    172.21.206.1
Vl256       205  110 P Active  local           172.21.208.3    172.21.208.1
Vl257       206  100 P Standby 172.21.210.3    local           172.21.210.1
Vl258       207  110 P Active  local           172.21.212.3    172.21.212.1
Vl259       208  110 P Active  local           172.21.214.3    172.21.214.1
Vl260       209  100 P Standby 172.21.216.3    local           172.21.216.1
Vl261       210  110 P Active  local           172.21.218.2    172.21.218.1
Vl262       211  100 P Standby 172.21.220.3    local           172.21.220.1
Vl263       212  110 P Active  local           172.21.224.3    172.21.224.1
Vl268       217  100 P Standby 172.21.228.3    local           172.21.228.1
Vl269       218  100 P Standby 172.21.230.3    local           172.21.230.1
Vl270       219  110 P Active  local           172.21.232.3    172.21.232.1
Vl301       1    110 P Active  local           172.21.1.3      172.21.1.1
Vl302       2    100 P Standby 172.21.2.3      local           172.21.2.1
Vl303       3    110 P Active  local           172.21.3.3      172.21.3.1
Vl304       4    100 P Standby 172.21.4.3      local           172.21.4.1
Vl305       5    110 P Active  local           172.21.5.3      172.21.5.1
Vl306       6    100 P Standby 172.21.6.3      local           172.21.6.1
Vl307       7    110 P Active  local           172.21.7.3      172.21.7.1
Vl308       8    100 P Standby 172.21.8.3      local           172.21.8.1
Vl309       9    110 P Active  local           172.21.9.3      172.21.9.1
Vl310       10   100 P Standby 172.21.10.3     local           172.21.10.1
Vl311       11   110 P Active  local           172.21.11.3     172.21.11.1
Vl312       12   100 P Standby 172.21.12.3     local           172.21.12.1
Vl313       13   110 P Active  local           172.21.13.3     172.21.13.1
Vl314       14   100 P Standby 172.21.14.3     local           172.21.14.1
Vl315       15   110 P Active  local           172.21.15.3     172.21.15.1
Vl316       16   100 P Standby 172.21.16.3     local           172.21.16.1
Vl317       17   110 P Active  local           172.21.17.3     172.21.17.1
Vl318       18   100 P Standby 172.21.18.3     local           172.21.18.1
Vl319       19   110 P Active  local           172.21.19.3     172.21.19.1
Vl320       20   100 P Standby 172.21.20.3     local           172.21.20.1
Vl321       21   110 P Active  local           172.21.21.3     172.21.21.1
Vl322       22   100 P Standby 172.21.22.3     local           172.21.22.1
Vl323       23   110 P Active  local           172.21.23.3     172.21.23.1
Vl324       24   100 P Standby 172.21.24.3     local           172.21.24.1
Vl325       25   110 P Active  local           172.21.25.3     172.21.25.1
Vl326       26   100 P Standby 172.21.26.3     local           172.21.26.1
Vl327       27   110 P Active  local           172.21.27.3     172.21.27.1
Vl328       28   100 P Standby 172.21.28.3     local           172.21.28.1
Vl330       30   100 P Standby 172.21.30.3     local           172.21.30.1
Vl331       31   110 P Active  local           172.21.31.3     172.21.31.1
Vl332       32   100 P Standby 172.21.32.3     local           172.21.32.1
Vl333       33   110 P Active  local           172.21.33.3     172.21.33.1
Vl334       34   100 P Standby 172.21.34.3     local           172.21.34.1
Vl335       35   110 P Active  local           172.21.35.3     172.21.35.1
Vl336       36   100 P Standby 172.21.36.3     local           172.21.36.1
Vl337       37   110 P Active  local           172.21.37.3     172.21.37.1
Vl338       38   100 P Standby 172.21.38.3     local           172.21.38.1
Vl339       39   110 P Active  local           172.21.39.3     172.21.39.1
Vl340       40   100 P Standby 172.21.40.3     local           172.21.40.1
Vl341       41   110 P Active  local           172.21.41.3     172.21.41.1
Vl342       42   100 P Standby 172.21.42.3     local           172.21.42.1
Vl343       43   110 P Active  local           172.21.43.3     172.21.43.1
Vl344       44   100 P Standby 172.21.44.3     local           172.21.44.1
Vl345       45   110 P Active  local           172.21.45.3     172.21.45.1
Vl346       46   100 P Standby 172.21.46.3     local           172.21.46.1
Vl347       47   110 P Active  local           172.21.47.3     172.21.47.1
Vl348       48   100 P Standby 172.21.48.3     local           172.21.48.1
Vl349       49   110 P Active  local           172.21.49.3     172.21.49.1
Vl350       50   100 P Standby 172.21.50.3     local           172.21.50.1
Vl351       51   110 P Active  local           172.21.51.3     172.21.51.1
Vl352       52   100 P Standby 172.21.52.3     local           172.21.52.1
Vl368       68   100 P Standby 172.21.68.3     local           172.21.68.1
Vl389       89   110 P Init    unknown         unknown         172.21.89.1
Vl390       90   100 P Init    unknown         unknown         172.21.90.1
Vl476       176  100 P Standby 172.21.176.3    local           172.21.176.1
Vl492       92   100 P Standby 172.21.192.3    local           172.21.192.1
Vl499       199  110 P Active  local           172.21.199.3    172.21.199.1
Vl500       254  110 P Active  local           172.21.29.19    172.21.29.18
Vl555       101  110 P Active  local           10.255.255.22   10.255.255.20
Vl556       59   110 P Active  local           10.255.255.62   10.255.255.60
Vl557       93   110 P Active  local           10.255.255.38   10.255.255.36
Vl558       94   110 P Active  local           10.255.255.46   10.255.255.44
Vl729       198  110 P Active  local           172.21.198.3    172.21.198.1
Vl900       255  100 P Standby 10.55.75.3      local           10.55.75.1
Vl902       1    110   Active  local           172.21.255.3    172.21.255.1
sh spanning-tree blockedports
Name                 Blocked Interfaces List
VLAN0002             Te3/3
VLAN0044             Te3/3
VLAN0360             Te3/3
VLAN0364             Po1, Po2
VLAN0468             Te3/3
Number of blocked ports (segments) in the system : 6
VLAN0360
  Spanning tree enabled protocol rstp
  Root ID    Priority    8552
             Address     0024.c480.1a40
             Cost        1
             Port        1666 (Port-channel2)
             Hello Time   2 sec  Max Age 20 sec  Forward Delay 15 sec
  Bridge ID  Priority    33128  (priority 32768 sys-id-ext 360)
             Address     0022.0deb.b800
             Aging Time 250
Interface           Role Sts Cost      Prio.Nbr Type
Te3/3               Altn BLK 2         128.259  P2p
Gi7/38              Desg FWD 4         128.806  P2p
Gi9/39              Desg FWD 4         128.1063 P2p
Gi9/40              Desg FWD 4         128.1064 P2p
Gi9/41              Desg FWD 4         128.1065 P2p
Po1                 Desg FWD 1         128.1665 P2p
Po2                 Root FWD 1         128.1666 P2p
sh int trunk
Te3/3               on           802.1q         trunking      1
Gi9/48              on           802.1q         trunking      1
Po1                 on           802.1q         trunking      1
Te3/3               1-4094
Po1                 1-4094
Po2                 1-4094
Te3/3               1-2,8-9,11,18,22,26,30,44-45,50,90,101,200,222-223,225,227,231,234,250-263,268-270,301-352,358-360,363-364,368,371-374,389-390,468,476,492,499-500,554-559,729,900-902
Po1                 1-2,8-9,11,18,22,26,30,44-45,50,90,101,200,222-223,225,227,231,234,250-263,268-270,301-352,358-360,363-364,368,371-374,389-390,468,476,492,499-500,554-559,729,900-902
Te3/3               1,8-9,11,18,22,26,30,45,50,90,101,200,222-223,225,227,231,234,250-263,268-270,301-352,358-359,363-364,368,371-374,389-390,476,492,499-500,554-559,729,900-902
Po1                 1,8-9,11,18,22,26,30,45,50,90,101,200,222-223,225,227,231,234,250-263,268-270,301-352,358-359,363,368,371-374,389-390,476,492,499-500,554-559,729,900-902
Po2                 1-2,390
sh vlan brief
VLAN Name                             Status    Ports
1    default                          active    Te3/6, Gi7/16, Gi7/21, Gi7/47, Gi9/32, Gi9/33
2    XXX                     active    Gi1/7, Gi1/11
50   TEST_VLAN2                       active
90   vlan90                           active
101  MANAGEMENT_NEW                   active
360  VLAN0360                         active
900  INTERCON_OLD_NET                 active
901  Proxy_old_CED                    active    Gi1/40
hello everybody....
I've solved this issue.....I was right !!!!
The problem was about the Port-channell between the CORE (6509-6513).
For some reasone the BPDU were not advertising ...indeed.... the show int po2 (port-channel master ) trunk  showed..
sh int po2 trunk
Po2                 1-4094
Po2                 1-2,390
This situation...bloked the forwarding for the Vlan id that aren't there.
thak you so much...
Hello David,
thanks for your feedback on this case.
It was an OSI layer2 issue, nothing related to the presence or absence of an SVI in vlan360 at cat6509 level of devices.
What have you done to fix?  the classic shut/no shut to trigger new negotiations and protocol exchanges on the affected port channel?
Best Regards
Giuseppe
Hello Giuseppe.
Yes i did...
The sh /no sh has forced the new negotiations and the exchanges for protocol LACP.
But the question was why the RSTP didn't work fine ?
The troubleshooting showed me  that the forwarding for all Vlans from the 6509 secondary to 6513 were forwarding to the link 10 Gb that should be in the block status, instead the 6509 primary saw as the root spanning tree for any Vlans (ex vlan 360) the Po2.
This made me crazy.....
