Stupid Flash Question
sabinj211
I am about to ask a stupid question so don't make too much fun of me. My flash is full and I was wondering is I could delete the c2800nm-advipservicesk9-mz.124-15.bin.
I'm pretty sure I can because it needs it to load but want to verify. I have a voip system without enough room for all required phone loads.
Jon Marshall
Hi Sabin
No one will make fun of you, NetPro is for solving people's problems.
If that is the image your router is running and you have no other images in your flash then no you cannot delete it unless you have an image elsewhere that the router could use to boot.
You can download a different image to flash and overwrite that one but your router will need an image in flash to boot.
Jon
Thank you that is what I figured. I'm going to have to figure out which files I can get rid of.
Do you happen to see anything that stands out as not needed? Your assistance is greatly appreciated.
sh flash
-#- --length-- -----date/time------ path
1 50933220 Jul 7 2007 14:59:14 -04:00 c2800nm-advipservicesk9-mz.124-15.T.bin
2 281506 Jul 7 2007 19:53:16 -04:00 ATA030100SCCP040211A.zup
3 638 May 23 2007 21:00:02 -04:00 CME_GUI_README.TXT
4 49599 Jul 7 2007 19:54:16 -04:00 S00105000200.sbn
5 2146 Jul 7 2007 19:55:44 -04:00 RingTonesReadme.txt
6 5138 Jul 7 2007 19:56:00 -04:00 PhoneloadReadme.txt
7 2453223 Jul 7 2007 20:45:52 -04:00 apps41.8-2-2ES1.sbn
8 435144 Jul 7 2007 20:46:10 -04:00 cnu41.8-2-2ES1.sbn
9 1029 Jul 7 2007 19:44:32 -04:00 CiscoLogo.gif
10 953 Jul 7 2007 19:47:02 -04:00 Delete.gif
11 2141085 Jul 7 2007 20:47:14 -04:00 cvm41sccp.8-2-2ES1.sbn
12 509001 Jul 7 2007 20:47:34 -04:00 dsp41.8-2-2ES1.sbn
13 229364 Jul 7 2007 20:48:02 -04:00 jar41sccp.8-2-2ES1.sbn
14 642 Jul 7 2007 20:48:32 -04:00 SCCP41.8-2-2SR1S.loads
15 642 Jul 7 2007 20:48:54 -04:00 term41.default.loads
16 1347 Jul 7 2007 19:49:34 -04:00 Plus.gif
17 47904 May 23 2007 21:00:12 -04:00 S00103020002.bin
18 49169 Jul 7 2007 19:53:50 -04:00 S00104000100.sbn
19 174 May 23 2007 21:00:12 -04:00 Tab.gif
20 4776 Jul 7 2007 19:43:46 -04:00 admin_user.html
21 668037 Jul 7 2007 19:44:08 -04:00 admin_user.js
22 642 Jul 7 2007 20:49:08 -04:00 term61.default.loads
23 16948 Jul 7 2007 19:47:18 -04:00 dom.js
24 864 Jul 7 2007 19:47:34 -04:00 downarrow.gif
25 6315 Jul 7 2007 19:48:04 -04:00 ephone_admin.html
26 4658 Jul 7 2007 19:48:32 -04:00 logohome.gif
27 3831 Jul 7 2007 19:48:50 -04:00 normal_user.html
28 81724 Jul 7 2007 19:49:22 -04:00 normal_user.js
29 843 Jul 7 2007 19:49:50 -04:00 sxiconad.gif
30 2471 Jul 7 2007 19:50:12 -04:00 telephony_service.html
31 870 Jul 7 2007 19:50:26 -04:00 uparrow.gif
32 10230 Jul 7 2007 19:51:12 -04:00 xml-test.html
33 3493 Jul 7 2007 19:50:42 -04:00 xml.template
34 1826 May 23 2007 21:01:34 -04:00 sdmconfig-28xx.cfg
35 861696 May 23 2007 21:02:42 -04:00 es.tar
36 1164288 May 23 2007 21:03:06 -04:00 common.tar
37 1038 May 23 2007 21:03:28 -04:00 home.shtml
38 113152 May 23 2007 21:03:50 -04:00 home.tar
39 527849 May 23 2007 21:04:12 -04:00 128MB.sdf
40 416354 May 23 2007 21:05:16 -04:00 sslclient-win-1.1.3.173.pkg
41 4207 Jul 3 2007 10:34:36 -04:00 SDM_Backup
42 6548 Jul 4 2007 17:59:22 -04:00 strt
43 5012 Sep 13 2007 10:56:22 -04:00 logo.xml
44 49986 Jul 31 2007 14:04:26 -04:00 S00105000300.sbn
45 16014 Jul 31 2007 15:02:16 -04:00 vtgo.cfg.xml
46 129828 Aug 9 2007 09:49:56 -04:00 P00308000400.bin
47 461 Aug 9 2007 09:50:14 -04:00 P00308000400.loads
48 701768 Aug 9 2007 09:50:36 -04:00 P00308000400.sb2
49 130232 Aug 9 2007 09:50:56 -04:00 P00308000400.sbn
50 496521 Aug 28 2007 14:33:58 -04:00 moh1.au
51 5012 Sep 13 2007 10:56:04 -04:00 logo.gif
52 427 Sep 13 2007 14:08:48 -04:00 DistinctiveRingList.xml
53 425 Sep 13 2007 14:08:34 -04:00 RingList.xml
54 10724 Sep 13 2007 11:41:32 -04:00 CTU24.raw
55 12156 Sep 13 2007 11:42:06 -04:00 asleep.raw
56 16080 Sep 13 2007 11:42:42 -04:00 Neuro.raw
57 35410 Sep 13 2007 14:09:28 -04:00 sax3.raw
Unfortunetly I have to keep the ringtones. they server a specific purpose for my call center.
You could delete some of those phoneloads provided you're not using them. Other than that I don't see anything that you can dump. You have a couple options:
1) Get a bigger flash card. The ISR will take up to a 1 GB CF mod. and technically you can use an off the shelf card from your favorite electronics store. Or you can play it safe and buy Cisco's. Either way it looks like a DOS file system so with a CF reader you easily can copy your files off and back on. Make sure to reformat it FAT (DOS), not FAT32.
2) Buy a USB stick drive to supplement the 64 MB card you have in it. Same stuff about size acquisition methods etc. from #1 apply.
