Sub interface Ip address over-laping
I'm doing a small school project for a small business with 5 departments and each department has 10 employees which makes a total of 50 employees. I used a 192.168.1.0 network address and a /27 as a subnet mask to subnet my network into 5 department which ended up giving me 8 subnets, 32 hosts and 30 usable addresses for each subnet. I had only one problem of assigning Ip address to the sub-interface of a router, I kept getting this error. Please help me solve this problem !
Router(config-sub if)#ip address 192.168.1.1 255.255.255.0
Router(config-sub if)#exit
Router(config)#interface gigabit Ethernet 0/0/0.20
Router(config-sub if)#encapsulation dot1Q 20
Router(config-sub if)#ip address 192.168.1.33 255.255.255.0
% 192.168.1.0 overlaps with GigabitEthernet0/0/0.10
please help !
 You are using the wrong mask
Should be
192.168.1.1 255.255.255.224
TotallyTodd
Hi, the proper subnet mask for a /27 would be 255.255.255.224 to allow for 8 subnets totally. The reason that this overlaps is because the 255.255.255.0 creates 1 subnet with a total of 254 host addresses totally. The rest looks good!
"Hi, the proper subnet mask for a /27 would be 255.255.255.224 to allow for 6 subnets totally."
Actually, a /24 provides 8 /27s (as OP correctly noted.)
Otherwise, as both @Flavio Miranda and @TotallyTodd note, you're using a /24 mask, when you need to use a /27 mask.
