Dear Experts,
I am confused with Subnet concept, for example I am taking 192.168.0.0 with Subnet Mask 255.255.240.
It's Host range will be 192.168.0.1 to 192.168.15.254.
Suppose If I will connect two computer with HUB/SWITCH as
Computer 1: Computer 2:
ip address = 192.168.0.7 ip address = 192.168.6.6
subnet mask = 255.255.240.0 subnet mask = 255.255.240.0
Now my Questions are:
Question1. will computer 1 communicate with computer 2 ?
Question2. will computer 2 communicate with computer 1 ?
Question3. any need of Router or L3 device to inter vlan/subnet routing for both computer subnet ?
KS
Solved! Go to Solution.
Hi Kuldeep,
Yes. Computer 1 knows it is located in network 192.168.0.0/20 - that is the result of the binary AND operation between its own IP address and its own netmask. When Computer 1 takes the IP address of Computer 2 and performs a binary AND with its own mask, it will arrive at the same network address 192.168.0.0/20. Therefore, Computer 1 knows that Computer 2 is in the same IP network.
Yes. The logic is the same as in the previous answer.
If you are asking whether computers 1 and 2 need a router to communicate with each other, then - no, they do not need any router, and even if there was a router, they would not use it. Because both computers are in the same IP network, they will communicate directly with each other.
Feel welcome to ask further!
Best regards,
Peter
Hi Kuldeep,
Best regards,
Peter
