subnet question help
Dudesux2012
Community Member
Hi iam kinda confused with this question.
1) Given 192.168.100.0 /24, subnet it so as to give 5 subnet
    show the table.
1.1) What is the first and last usable ip address of the zeroth subnet?
1.2) What is the first and last usable ip address of the 2nd subnet?
I would be very appreciated to who can answer to this questions.
Sergey Fer
Level 7
Level 7
You can't get exactly 5 subnets without using VLSM. You can get 8 subnets by using /27 (255.255.255.224) mask.
Zeroth subnet is 192.168.100.0/27, first usable address is 192.168.100.1, last - 192.168.100.30
Second subnet is 192.168.100.64/27, first address is 192.168.100.65, last - 192.168.100.90
If you use VLSM you may get any result you want. It would not be deterministic.
Sergey Fer
Level 7
Level 7
omg thank you i thought my answer was wrong
but questions 1.3) how do solve it? what i get is 65~94 usable ip
As Fer said to get 5 subnet u use a /27 with the no of valid subnets as 8 and a block size of 32 with 30 being the valid hosts ( remember one goes for n/w address and one for broadcast ) so now.. calculate the range
Valid subnets --> 0,32,64,96,128,160, etc etc.. till 224
so to answer ur 1.3) how to solve it? the usuable IPs which u will get is from 192.168.100.65 - 192.168.100.94 ( 192.168.100.64 as the n/w address and 192.168.100.95 as the broadcast address) .. and that makes your answer right
Note: You still got 3 more usuable subnets which u can have fun with
