Subnetting help
DavisCorbin95
Hey guys, I am level 1 networker in training, any advice or tricks I can borrow from you guys in subnetting?
Lets use example 193.15.7.0 with 10 subnetworks. I would just need overall advice on how to get:
Bits borrowed?
Bits Remaining?
and Writing the subnets bits in 1's and host as 0's.
Julio E. Moisa
You could begin learning the Formulas used to subnetting, there are many ways to subnetting, each pleople has its own method, I use the following for example:
Formulas:
Available bits:
32 - CIDR =  # available bits to subnetting
n = represents bits that will be working with the available bits through 1 or 0.
To get X amount of subnets
2^n >= # of subnets required
To get X amount of hosts
[(2^n) - 2) >= # of hosts required
To get the block size:
256 - (Alterared Octets) = Size.
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Joseph W. Doherty
"trick" - find a subnetting calculator.
If you're looking for how to do it manually, such a question is better posted on Cisco's learning forums.
Reza Sharifi
Here is a link to learn all the basics.
http://sysnetnotes.blogspot.in/2013/07/subnetting-made-easy.html
im checking out the site now, its really convenient.
Julio E. Moisa
Formulas:
Available bits:
Hope it is useful
