Subnetting question
rprudent
Hi all,
Can someone explain why these 2 ip addresses are correct and show how the ip's where achieved. Thanks
michael.leblanc
Level 9
Level 9
rprudent:
The easiest way to get a handle on these, is with a thought process similar to the following:
  • With a mask of 255.255.254.0, it is the third octet that distinguishes adjacent Networks IDs.
  • If you subtract the value of the third octet (254) from 256 (0 - 255  represents 256 possible values), you will get 2.
  • This value (2) represents the increment between Network IDs.
E.g.: 113.10.4.0 255.255.254.0 would yield the following Network IDs:
113.10.0.0
113.10.2.0
113.10.4.0
113.10.6.0
. etc.
113.10.252.0
113.10.254.0
Note: that the third octet is incrementing by 2.
  • The address that follows a Network ID (e.g.: 113.10.4.0), is the first assignable host address (e.g.: 113.10.4.1).
  • The address that precedes the "next" Network ID (e.g.: 113.10. 6.0), would be the broadcast address (e.g.: 113.10.5.255).
  • The address that precedes the broadcast address (e.g.: 113.10.5.255), would be the last assignable host address (e.g.: 113.10.5.254).
Answer Assessment
A.     113.10.4.0 255.255.254.0 defines an address space of 113.10.4.0 - 113.10.5.255
The network ID would be: 113.10.4.0
The broadcast address would be 113.10.5.255
The host address range would be 113.10.4.1 - 113.10.5.254, which is not inclusive of 113.10.4.0
Note: The address in question, happens to be a Network ID.
B.     186.54.3.0 255.255.254.0 defines an address space of 186.54.2.0 - 186.54.3.255
The network ID would be: 186.54.2.0
The broadcast address would be 186.54.3.255
The host address range would be 186.54.2.1 - 186.54.3.254, which is inclusive of 186.54.3.0
Note: The address in question, is host assignable.
C.     175.33.3.255 255.255.254.0 defines an address space of 175.33.2.0 - 175.33.3.255
The network ID would be: 175.33.2.0
The broadcast address would be 175.33.3.255
The host address range would be 175.33.2.1 - 175.33.3.254, which is not inclusive of 175.33.3.255
Note: The address in question, happens to be the broadcast address.
D.     26.35.2.255 255.255.254.0 defines an address space of 26.35.2.0 - 26.35.3.255
The network ID would be: 26.35.2.0
The broadcast address would be 26.35.3.255
The host address range would be 26.35.2.1 - 26.35.3.254, which is inclusive of 26.35.2.255
Note: The lesson is that a fourth octet of 255, does not always mean a broadcast address.
E.     17.35.36.0 255.255.254.0 defines an address space of 17.35.36.0 - 17.35.37.255
The network ID would be: 17.35.36.0
The broadcast address would be 17.35.37.255
The host address range would be 17.35.36.1 - 17.35.37.254, which is not inclusive of 17.35.36.0
Best Regards,
Mike
6 Replies 6
Nagaraja Thanthry
The first one is invalid because all the host bits are zero's (last 9 bits are host bits for a 255.255.254.0 mask)
The second one is a valid address as the host bits will be 100000000 (This satisfies the condition that all host bits should not be zeros)
Third one is invalid because all host bits are one's
Fourth one is valid because the host bits are 011111111
Last one is invalid because again all the host bits are zero's.
Hope this helps.
NT
hello ,
i have one question,, i donnot understand whether this ip add can assign to a host . please help
203.148.0.255 / 255.255.254.0
i know netmask 255.255.254.0   broadcast address is  203.148.1.255 .
If you have enabled "IP classless" feature, then you can assign that address. If not, that is an invalid address as 203.x.x.x is a Class C address and the default (classful) mask is 255.255.255.0
Hope this helps.
Regads,
NT
shf-gw1(config)#interface vlan1
shf-gw1(config-if)# ip address 203.148.0.255 255.255.255.0 secondary
Bad mask /24 for address 203.148.0.255
shf-gw1(config-if)# ip address 203.148.1.0 255.255.254.0 secondary
shf-gw1(config-if)# ip address 203.148.0.255 255.255.254.0 secondary
shf-gw1(config-if)#
shf-gw1(config-if)#
shf-gw1(config-if)#do ping 203.148.1.0 re 100
Sending 100, 100-byte ICMP Echos to 203.148.1.0, timeout is 2 seconds:
Success rate is 100 percent (100/100), round-trip min/avg/max = 1/1/9 ms
shf-gw1(config-if)#do ping 203.148.0.255 re 100
Sending 100, 100-byte ICMP Echos to 203.148.0.255, timeout is 2 seconds:
shf-gw1(config-if)#do show run interface vlan1
Building configuration...
Current configuration : 178 bytes
interface Vlan1
ip address 192.168.5.45 255.255.255.0
load-interval 30
end
shf-gw1(config-if)#
shf-gw1(config)# do ping 192.168.5.255
Sending 5, 100-byte ICMP Echos to 192.168.5.255, timeout is 2 seconds:
Reply to request 0 from 192.168.5.1, 16 ms
Reply to request 1 from 192.168.160.1, 1 ms
Reply to request 1 from 192.168.5.254, 1 ms
Reply to request 1 from 192.168.5.102, 1 ms
Reply to request 1 from 192.168.5.103, 1 ms
Reply to request 1 from 192.168.5.3, 1 ms
Reply to request 1 from 192.168.5.1, 1 ms
Reply to request 2 from 192.168.160.1, 1 ms
Reply to request 2 from 192.168.5.254, 1 ms
Reply to request 2 from 192.168.5.102, 1 ms
Reply to request 2 from 192.168.5.103, 1 ms
Reply to request 2 from 192.168.5.3, 1 ms
Reply to request 2 from 192.168.5.1, 1 ms
Reply to request 3 from 192.168.5.1, 1 ms
Reply to request 3 from 192.168.160.1, 1 ms
Reply to request 3 from 192.168.5.254, 1 ms
Reply to request 3 from 192.168.5.102, 1 ms
Reply to request 3 from 192.168.5.103, 1 ms
Reply to request 3 from 192.168.5.3, 1 ms
Reply to request 4 from 192.168.160.1, 1 ms
Reply to request 4 from 192.168.5.254, 1 ms
Reply to request 4 from 192.168.5.103, 1 ms
Reply to request 4 from 192.168.5.102, 1 ms
thanks NT , like this , i understood .. very clear
yoda95823
Community Member
Here are some sites to learn and practice subnetting:
http://easysubnet.com/
http://subnettingquestions.com
michael.leblanc
Level 9
Level 9
rprudent:
113.10.0.0
113.10.2.0
113.10.4.0
113.10.6.0
. etc.
113.10.252.0
113.10.254.0
Answer Assessment
Best Regards,
Mike
