Subnetting
jonk34567
Level 4
Level 4
for below attached diagram i did the sub-netting below. is it correct ? also if the static routing is used what are the routing table entries in each router.
  192.168.3.0/24  is  the network
5 computers  ---192.168.3.0/29
7 computers  ---192.168.3.0/28
14 computers  ---192.168.3.16 /28
10 Replies 10
Mark Malone
your host section is correct in terms of the amount of usable users per subnet but its all the same subnet /24 your breaking down so you cant have 2 network subnets that both start with .0
192.168.3.0/29 = 192.168.3.1 - 6 usable
192.168.3.8/29 = 192.168.3.9 - 15 usable
192.168.3.16/28 = 192.168.3.17 - 30 usable
are they wrong because both start with 0 ? but they are 2 different subnet masks
Yes because they both cant start with same ip address space , even though there different subnet masks there under same supernet /24 the /29s and /28 exist under this space so only 1 of them can take the first set of ips
also may i know the routing table entries in each router
I think it was a typo, but using VLSM the network should be:
192.168.3.0/28   --- 14 hosts
192.168.3.16/29  --- 7 hosts
192.168.3.24/29  --- 5 hosts
192.168.3.32/30  -- P2P
192.168.3.36/30  -- P2P
192.168.3.40/30  -- P2P
192.168.3.42/30  -- P2P
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
You could see the entries through; show ip route, on each router.
Hello
Have a look at the attach file -it may provide you with a clearer explanation  to your query.
res
Paul
Kind Regards
Paul
thank you very much but it does not have any routing table entries
Hello
Apologies but what do yo mean by routing entry's?
res
Paul
Kind Regards
Paul
