SUP720-3B show command for SP-DRAM and RP-DRAM
MARTIN FUNKE
Can someone please tell the show commands for displaying the actual size of SP- and RP-DRAM on a SUP720-3B?
Which DRAM-size is displayed with the show version command? SP or RP?
Thanks for your support in advance.
Martin Funke.
jasonfmic
Try
show platform hardware capacity cpu
jasonfmic
Try
Thanks! That command gives me the needed information.
fyi: I could also get the information with:
remote command switch show version
BR,
Martin Funke.
