08-09-2011 05:35 AM - edited 03-07-2019 01:36 AM
Hi!
I'm new to this forum.
I would like to know if a card X6848 is compatible with the supervisor 720. In the data sheet but put that on the configurator module is included you DFC4 do not know if you can remove to support DFC3 of 720.
08-09-2011 05:46 AM
Sup 720 doesnt support x6848 line card because it is having DFC4. So it will be supported by supervisor engines which is compatible with DFC4.
| 48-Port Gigabit Ethernet Fiber Module=> | WS-X6848-SFP-2T (with DFC4) |
2T Supervisor engines supports DFC4 line cards
Product Description Part Number
Supervisor 2T with 2 ports 10GbE and MSFC5 PFC4 VS-S2T-10G
Supervisor 2T with 2 ports 10GbE and MSFC5 PFC4XL VS-S2T-10G-XL
Datasheet for 2T sup engines:
http://www.cisco.com/en/US/prod/collateral/modules/ps2797/ps11878/data_sheet_c78-648214.html
Hope this answers your questions
Cheers
Somu
Rate helpful posts
08-09-2011 05:49 AM
Hello Diego,
Sup 720 has PFC3, supports DFC3 LC's and i guess the 6848 is supported from SUP 2T and not on Sup 720.Sup 2T has DFC4 LC support.
This comes in two flavours 48 port fiber/copper,
WS-X6848-SFP-2TXL (with DFC4XL)
Links for your reference,
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SY/release/notes/ol_20679.html
Ricky Micky
* Pls rate if this is useful
