Supervisor engine 720-3BXL Memory question
aamsaleg
Can someone tell me how much RAM does a SUP720-3BXL have by default ?
2 Accepted Solutions
gearnsc
the 3BXL comes maxed out with 1 gb of ram.
http://www.cisco.com/warp/public/765/tools/quickreference/catalyst6000supervisors.pdf
Hope this helps, rate if it does
andrew.burns
Level 7
Level 7
The 3BXL has 1GB on both SP and RP by default.
Andrew.
gearnsc
andrew.burns
Level 7
Level 7
Andrew.
