Supervisor Engine 720 errors
ahmad82pkn
Level 7
Level 7
hi, i have a standalone SUP720, no traffic is passing through it. only one port connected for remote telnet, its kind of backup device.
today i checked its log, and there are some wiered message.
is it a software bug or my SUP has gone bad?
any suggestion/help would be appreciated.
*Apr 19 18:19:02: %CONST_DIAG-SP-3-HM_TEST_FAIL: Module 6 TestSPRPInbandPing consecutive failure count:5
*Apr 19 18:19:03: %CONST_DIAG-SP-6-HM_TEST_INFO: CPU util(5sec): SP=7% RP=2% Traffic=0%
netint_thr_active[0], Tx_Rate[658], Rx_Rate[80], dev=4[IPv6, fail=5]
*Apr 19 18:20:29: %CONST_DIAG-SP-3-HM_TEST_FAIL: Module 6 TestSPRPInbandPing consecutive failure count:10
*Apr 19 18:20:30: %CONST_DIAG-SP-6-HM_TEST_INFO: CPU util(5sec): SP=3% RP=0% Traffic=0%
netint_thr_active[0], Tx_Rate[676], Rx_Rate[100], dev=4[IPv6, fail=10]
*Apr 19 18:21:56: %CONST_DIAG-SP-3-HM_TEST_FAIL: Module 6 TestSPRPInbandPing consecutive failure count:15
*Apr 19 18:21:57: %CONST_DIAG-SP-6-HM_TEST_INFO: CPU util(5sec): SP=1% RP=0% Traffic=0%
netint_thr_active[0], Tx_Rate[636], Rx_Rate[80], dev=4[IPv6, fail=15]
*Apr 19 18:23:23: %CONST_DIAG-SP-3-HM_TEST_FAIL: Module 6 TestSPRPInbandPing consecutive failure count:20
*Apr 19 18:23:24: %CONST_DIAG-SP-6-HM_TEST_INFO: CPU util(5sec): SP=7% RP=0% Traffic=0%
netint_thr_active[0], Tx_Rate[636], Rx_Rate[80], dev=4[IPv6, fail=20]
*Apr 19 18:24:50: %CONST_DIAG-SP-3-HM_TEST_FAIL: Module 6 TestSPRPInbandPing consecutive failure count:25
*Apr 19 18:24:51: %CONST_DIAG-SP-6-HM_TEST_INFO: CPU util(5sec): SP=5% RP=0% Traffic=0%
netint_thr_active[0], Tx_Rate[538], Rx_Rate[20], dev=4[IPv6, fail=25]
*Apr 19 18:26:16: %CONST_DIAG-SP-3-HM_TEST_FAIL: Module 6 TestSPRPInbandPing consecutive failure count:30
*Apr 19 18:26:17: %CONST_DIAG-SP-6-HM_TEST_INFO: CPU util(5sec): SP=3% RP=1% Traffic=0%
netint_thr_active[0], Tx_Rate[578], Rx_Rate[40], dev=4[IPv6, fail=30]
*Apr 19 18:27:43: %CONST_DIAG-SP-3-HM_TEST_FAIL: Module 6 TestSPRPInbandPing consecutive failure count:35
*Apr 19 18:27:44: %CONST_DIAG-SP-6-HM_TEST_INFO: CPU util(5sec): SP=6% RP=0% Traffic=0%
netint_thr_active[0], Tx_Rate[608], Rx_Rate[80], dev=4[IPv6, fail=35]
*Apr 19 18:29:10: %CONST_DIAG-SP-3-HM_TEST_FAIL: Module 6 TestSPRPInbandPing consecutive failure count:40
*Apr 19 18:29:11: %CONST_DIAG-SP-6-HM_TEST_INFO: CPU util(5sec): SP=5% RP=2% Traffic=0%
netint_thr_active[0], Tx_Rate[670], Rx_Rate[100], dev=4[IPv6, fail=40]
*Apr 19 18:30:36: %CONST_DIAG-SP-3-HM_TEST_FAIL: Module 6 TestSPRPInbandPing consecutive failure count:45
*Apr 19 18:30:37: %CONST_DIAG-SP-6-HM_TEST_INFO: CPU util(5sec): SP=3% RP=0% Traffic=0%
netint_thr_active[0], Tx_Rate[608], Rx_Rate[80], dev=4[IPv6, fail=45]
*Apr 19 18:32:03: %CONST_DIAG-SP-3-HM_TEST_FAIL: Module 6 TestSPRPInbandPing consecutive failure count:50
*Apr 19 18:32:04: %CONST_DIAG-SP-6-HM_TEST_INFO: CPU util(5sec): SP=2% RP=0% Traffic=0%
netint_thr_active[0], Tx_Rate[698], Rx_Rate[100], dev=4[IPv6, fail=50]
*Apr 19 18:33:30: %CONST_DIAG-SP-3-HM_TEST_FAIL: Module 6 TestSPRPInbandPing consecutive failure count:55
*Apr 19 18:33:31: %CONST_DIAG-SP-6-HM_TEST_INFO: CPU util(5sec): SP=3% RP=0% Traffic=0%
netint_thr_active[0], Tx_Rate[658], Rx_Rate[80], dev=4[IPv6, fail=55]
*Apr 19 18:34:56: %CONST_DIAG-SP-3-HM_TEST_FAIL: Module 6 TestSPRPInbandPing consecutive failure count:60
*Apr 19 18:34:57: %CONST_DIAG-SP-6-HM_TEST_INFO: CPU util(5sec): SP=3% RP=0% Traffic=0%
netint_thr_active[0], Tx_Rate[653], Rx_Rate[100], dev=4[IPv6, fail=60]
*Apr 19 18:36:23: %CONST_DIAG-SP-3-HM_TEST_FAIL: Module 6 TestSPRPInbandPing consecutive failure count:65
*Apr 19 18:36:24: %CONST_DIAG-SP-6-HM_TEST_INFO: CPU util(5sec): SP=4% RP=2% Traffic=0%
netint_thr_active[0], Tx_Rate[578], Rx_Rate[60], dev=4[IPv6, fail=65]
*Apr 19 18:36:58: %CONST_DIAG-SP-6-HM_TEST_RECOVERED: Module 6 TestSPRPInbandPing recovered after 66 consecutive failure(s)
*Apr 19 18:38:24: %CONST_DIAG-SP-3-HM_TEST_FAIL: Module 6 TestSPRPInbandPing consecutive failure count:5
*Apr 19 18:38:25: %CONST_DIAG-SP-6-HM_TEST_INFO: CPU util(5sec): SP=3% RP=0% Traffic=0%
netint_thr_active[0], Tx_Rate[653], Rx_Rate[100], dev=4[IPv6, fail=5]
*Apr 19 18:39:35: %CONST_DIAG-SP-6-HM_TEST_RECOVERED: Module 6 TestSPRPInbandPing recovered after 8 consecutive failure(s)
*Apr 19 18:42:08: %CONST_DIAG-SP-3-HM_TEST_FAIL: Module 6 TestSPRPInbandPing consecutive failure count:5
*Apr 19 18:42:09: %CONST_DIAG-SP-6-HM_TEST_INFO: CPU util(5sec): SP=4% RP=0% Traffic=0%
netint_thr_active[0], Tx_Rate[670], Rx_Rate[100], dev=4[IPv6, fail=5]
*Apr 19 18:43:34: %CONST_DIAG-SP-6-HM_TEST_RECOVERED: Module 6 TestSPRPInbandPing recovered after 9 consecutive failure(s)
26 Replies 26
Reza Sharifi
These messages are from Module 6.  Is your sup in modules 6 or is this a line card?
What is the output of "sh module"?
yes its SUP in module 6
6506BK>sh module
Mod Ports Card Type                              Model              Serial No.
  1   48  SFM-capable 48 port 10/100/1000mb RJ45 WS-X6548-GE-TX
  2   48  48 port 10/100 mb RJ-45 ethernet       WS-X6248-RJ-45
  3   48  SFM-capable 48-port 10/100 Mbps RJ45   WS-X6548-RJ-45
  4   48  SFM-capable 48 port 10/100/1000mb RJ45 WS-X6548-GE-TX
  5   48  48 port 10/100 mb RJ-45 ethernet       WS-X6248-RJ-45
  6    2  Supervisor Engine 720 (Active)         WS-SUP720-BASE
Make sure the supervisor card is properly inserted/seated on the slot.
If it is, then contact Cisco TAC and get the card RMA-ed.
Will do this excercise and update.
In addition to what Leo suggested, it maybe also helpful if you load a different version of IOS.  It could be software issue.
I have same IOS running on my other 720 SUP/6506 with same cards and hardware. so i believe it might not be software issue?
Hi Ahmed,
This error message means that there was no communication between the
supervisor and the MSFC. This is most likely a hardware issue that could
however have been transient. The usual procedure is to monitor the router to
be sure it does not reoccur. If it happens again, then supervisor needs to
be RMA.
Whats the status of this module under show module?
Also plan for RMA of the module.
Inayath
*Plz rate all usefull posts.
Error keeps coming, they enver stops.
show module shows minor errors.
6506BK#sh module
Mod MAC addresses                       Hw    Fw           Sw           Status
  1  0008.7dce.fae8 to 0008.7dce.fb17  10.1   7.2(1)       8.5(0.46)RFW Ok
  2  0050.f0af.a174 to 0050.f0af.a1a3   1.1   4.2(0.24)VAI 8.5(0.46)RFW Ok
  3  0008.7dcd.f9f0 to 0008.7dcd.fa1f   6.1   6.3(1)       8.5(0.46)RFW Ok
  4  0013.1a0e.0d20 to 0013.1a0e.0d4f  10.1   7.2(1)       8.5(0.46)RFW Ok
  5  00d0.bce8.aba0 to 00d0.bce8.abcf   1.1   4.2(0.24)VAI 8.5(0.46)RFW Ok
  6  0011.21b5.6c34 to 0011.21b5.6c37   3.2   8.1(3)       12.2(18)SXF1 Ok
Mod  Sub-Module                  Model              Serial       Hw     Status
  6  Policy Feature Card 3       WS-F6K-PFC3A          2.4    Ok
  6  MSFC3 Daughterboard         WS-SUP720            2.4    Ok
Mod  Online Diag Status
  1  Minor Error
  2  Pass
  3  Minor Error
  4  Minor Error
  5  Pass
  6  Minor Error
Canto do RMA, since ots not under RMA contract with Cisco :-s
Hi Ahmed,
If no contract for RMA. Then I would suggest to do the Hard Reset of the module on this switch and update me the result.
1- Remove all the modules which are showing Minor Error and insert it one by one.
2- Get the following outputs:
1- Show module
2- show logging
3- show diagnostic result module all.
Inayath
Hi Inayat,
Sorry i am late here , actually had to involve onshore field support to help me out.
i have taken out all modules, and now only SUP720 and one FastEthernet module present in the Switch.
i asked Field support to remove all Cards, and then put back Sup720 and one FastEthernet module.
here is output of your requested commands, i hope you can guid me in some direction to resolve this issue
sh module
  1  Minor Error
  6  Minor Error
6506BK#sh logging
Syslog logging: enabled (0 messages dropped, 0 messages rate-limited, 0 flushes, 0 overruns)
    Console logging: level debugging, 54 messages logged
    Monitor logging: level debugging, 0 messages logged
    Buffer logging: level debugging, 54 messages logged
    Exception Logging: size (4096 bytes)
    Count and timestamp logging messages: disabled
    Trap logging: level informational, 45 message lines logged
Log Buffer (8192 bytes):
00:01:01: curr is 0x0
00:01:01: RP: Currently running ROMMON from S (Gold) region
*May 15 14:31:36: %SYS-6-CLOCKUPDATE: System clock has been updated from 19:31:36 UTC Wed May 15 2013 to 14:31:36 EST Wed May 15 2013, configured from console by console.
*May 15 15:31:36: %SYS-6-CLOCKUPDATE: System clock has been updated from 14:31:36 EST Wed May 15 2013 to 15:31:36 EDT Wed May 15 2013, configured from console by console.
*May 15 15:32:10: %SYS-5-CONFIG_I: Configured from memory by console
*May 15 15:32:11: %SYS-5-RESTART: System restarted --
IOS (tm) s72033_rp Software (s72033_rp-IPSERVICESK9_WAN-M), Version 12.2(18)SXF17, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by cisco Systems, Inc.
Compiled Fri 25-Sep-09 10:53 by ccai
*May 15 15:32:11: %MFIB_CONST_RP-6-REPLICATION_MODE_CHANGE: Replication Mode Change Detected. Current system replication mode is Ingress
*May 15 15:32:12: %SYS-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
Firmware compiled 15-Jul-09 16:40 by integ Build [100]
*May 15 15:32:12: %OIR-SP-6-CONSOLE: Changing console ownership to route processor
*May 15 15:32:13: %SYS-SP-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
*May 15 15:32:13: %FILESYS-SP-5-MISMATCH: bootflash device programming algorithm mismatch detected, reformat is recommended
00:01:09: SP: SP: Currently running ROMMON from S (Gold) region
*May 15 15:32:14: %SYS-SP-5-RESTART: System restarted --
IOS (tm) s72033_sp Software (s72033_sp-IPSERVICESK9_WAN-M), Version 12.2(18)SXF17, RELEASE SOFTWARE (fc1)
Compiled Fri 25-Sep-09 11:01 by ccai
*May 15 15:32:14: %OIR-SP-6-INSPS: Power supply inserted in slot 1
*May 15 15:32:14: %C6KPWR-SP-4-PSOK: power supply 1 turned on.
*May 15 15:32:14: %OIR-SP-6-INSPS: Power supply inserted in slot 2
*May 15 15:32:16: %C6KENV-SP-4-FANHIOUTPUT: Version 2 high-output fan-tray is in effect
*May 15 15:32:20: %FABRIC-SP-5-FABRIC_MODULE_ACTIVE: The Switch Fabric Module in slot 6 became active.
*May 15 15:32:20: %DIAG-SP-6-RUN_MINIMUM: Module 6: Running Minimal Diagnostics...
*May 15 15:32:46: %DIAG-SP-3-MINOR: Module 6: Online Diagnostics detected a Minor Error. Please use 'show diagnostic result ' to see test results.
*May 15 15:32:46: %CONST_DIAG-SP-3-BOOTUP_TEST_FAIL: Module 6: TestFibDevices failed
*May 15 15:32:46: %CONST_DIAG-SP-3-BOOTUP_TEST_FAIL: Module 6: TestIPv6FibShortcut failed
*May 15 15:32:46: %CONST_DIAG-SP-3-BOOTUP_TEST_FAIL: Module 6: TestL3VlanMet failed
*May 15 15:32:46: %CONST_DIAG-SP-3-BOOTUP_TEST_FAIL: Module 6: TestTransceiverIntegrity failed on port(s) 1
*May 15 15:32:46: %PM_SCP-SP-3-TRANSCEIVER_UNSUPPORTED: Unsupported transceiver in LAN port 6/1
*May 15 15:32:46: %PM_SCP-SP-3-TRANSCEIVER_UNSUPPORTED: Unsupported transceiver in LAN port 6/2
*May 15 15:32:47: %OIR-SP-6-INSCARD: Card inserted in slot 6, interfaces are now online
*May 15 15:32:49: %DIAG-SP-6-RUN_MINIMUM: Module 1: Running Minimal Diagnostics...
*May 15 15:33:00: %DIAG-SP-3-MINOR: Module 1: Online Diagnostics detected a Minor Error. Please use 'show diagnostic result ' to see test results.
*May 15 15:33:00: %CONST_DIAG-SP-3-BOOTUP_TEST_FAIL: Module 1: TestL3VlanMet failed
*May 15 15:33:01: %OIR-SP-6-INSCARD: Card inserted in slot 1, interfaces are now online
*May 15 15:34:14: %CONST_DIAG-SP-3-HM_TEST_FAIL: Module 6 TestSPRPInbandPing consecutive failure count:5
*May 15 15:34:15: %CONST_DIAG-SP-6-HM_TEST_INFO: CPU util(5sec): SP=9% RP=0% Traffic=0%
netint_thr_active[0], Tx_Rate[698], Rx_Rate[100], dev=4[IPv6, fail=5]
*May 15 15:35:41: %CONST_DIAG-SP-3-HM_TEST_FAIL: Module 6 TestSPRPInbandPing consecutive failure count:10
*May 15 15:35:42: %CONST_DIAG-SP-6-HM_TEST_INFO: CPU util(5sec): SP=3% RP=0% Traffic=0%
netint_thr_active[0], Tx_Rate[658], Rx_Rate[80], dev=4[IPv6, fail=10]
*May 15 15:37:08: %CONST_DIAG-SP-3-HM_TEST_FAIL: Module 6 TestSPRPInbandPing consecutive failure count:15
*May 15 15:37:09: %CONST_DIAG-SP-6-HM_TEST_INFO: CPU util(5sec): SP=3% RP=0% Traffic=0%
netint_thr_active[0], Tx_Rate[698], Rx_Rate[100], dev=4[IPv6, fail=15]
*May 15 15:38:34: %CONST_DIAG-SP-3-HM_TEST_FAIL: Module 6 TestSPRPInbandPing consecutive failure count:20
*May 15 15:38:35: %CONST_DIAG-SP-6-HM_TEST_INFO: CPU util(5sec): SP=4% RP=0% Traffic=0%
netint_thr_active[0], Tx_Rate[556], Rx_Rate[40], dev=4[IPv6, fail=20]
*May 15 15:40:01: %CONST_DIAG-SP-3-HM_TEST_FAIL: Module 6 TestSPRPInbandPing consecutive failure count:25
*May 15 15:40:02: %CONST_DIAG-SP-6-HM_TEST_INFO: CPU util(5sec): SP=7% RP=0% Traffic=0%
*May 15 15:40:53: %CONST_DIAG-SP-6-HM_TEST_RECOVERED: Module 6 TestSPRPInbandPing recovered after 27 consecutive failure(s)
6506BK#      sh diagnostic result module all
Current bootup diagnostic level: minimal
Module 1: SFM-capable 48 port 10/100/1000mb RJ45
  Overall Diagnostic Result for Module 1 : MINOR ERROR
  Diagnostic level at card bootup: minimal
  Test results: (. = Pass, F = Fail, U = Untested)
    1) TestLoopback:
   Port  1  2  3  4  5  6  7  8  9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24
   Port 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
    2) TestSynchedFabChannel -----------> .
    3) TestL3VlanMet -------------------> F
    4) TestIngressSpan -----------------> .
    5) TestEgressSpan ------------------> .
    6) TestAsicMemory ------------------> U
    7) TestFirmwareDiagStatus ----------> .
    😎 TestEobcStressPing --------------> U
Module 6: Supervisor Engine 720 (Active)
  Overall Diagnostic Result for Module 6 : MINOR ERROR
    1) TestScratchRegister -------------> .
    2) TestSPRPInbandPing --------------> F
    3) TestTransceiverIntegrity:
      Port  1  2
            F  F
    4) TestActiveToStandbyLoopback:
      Port  1  2
            U  U
    5) TestLoopback:
      Port  1  2
    6) TestNewIndexLearn ---------------> .
    7) TestDontConditionalLearn --------> .
    😎 TestBadBpduTrap -----------------> .
    9) TestMatchCapture ----------------> .
   10) TestProtocolMatchChannel --------> .
   11) TestFibDevices ------------------> F
   12) TestIPv4FibShortcut -------------> .
   13) TestL3Capture2 ------------------> .
   14) TestIPv6FibShortcut -------------> F
   15) TestMPLSFibShortcut -------------> .
   16) TestNATFibShortcut --------------> .
   17) TestAclPermit -------------------> .
   18) TestAclDeny ---------------------> .
   19) TestQoSTcam ---------------------> .
   20) TestL3VlanMet -------------------> F
   21) TestIngressSpan -----------------> .
   22) TestEgressSpan ------------------> .
   23) TestNetflowInlineRewrite:
      Port  1  2
            U  U
   24) TestFabricSnakeForward ----------> .
   25) TestFabricSnakeBackward ---------> .
   26) TestTrafficStress ---------------> U
   27) TestFibTcamSSRAM ----------------> U
   28) TestAsicMemory ------------------> U
   29) TestNetflowTcam -----------------> U
   30) ScheduleSwitchover --------------> U
   31) TestFirmwareDiagStatus ----------> .
   32) TestFabricFlowControlStatus -----> U
Thank you for Every one help and interest so far
Hi Ahmed,
Try thi:
2- Just insert the Sup module on Slot 5 and check if that passes the test.
3- If you got to see as success then wait for few mins to see if that works out.
4- then try inserting module 2 and check.
5- follow the same if the sup worked fine.
If all this fails then its indication of back plane issue.
Inayath
ramprasad13
Community Member
What recent change made on the device before seeing this error.
Sent from Cisco Technical Support Android App
it has been sitting idle since year i guess never looked at it since it was a backup hardware to be used in extreme cases, recently was just checking it by chance. and found these errors.
tried soft reload. but error still there.
I have had no end of problems with supervisor modules for 6500 series. As others suggest, switch IOS and ROMMON to the latest available General Release. Avoid early deployment (they have ED in the filename).
There is a battery on the card that acts like a CMOS battery on a standard PC motherboard. If the above doesn't fix it, try taking that out and putting back in. TAC got me to do that for a bug I was getting that wouldn't let me change confreg in ROMMON or Native IOS. Do you have a spare or another router using a Sup720 that you could swap out? That would rule out a line card failure.
Just wrote all that and noticed this:
The problem is whatever is in 6/2. I put money on it being a non-cisco SFP. There are two commands you are going to want here:
To enable your non-cisco transceiver:
service unsupported-transceiver
That is a hidden command, tab and ? will not help you enter that command.
Then you probably want to prevent error-disable caused by non-Cisco SFP. To do this enter:
no errdisable detect cause gbic-invalid
Then perform a reload. Even though it takes the command I am not sure it is processed until next boot up.
Caveat: The above is likely to not make you best friends with TAC. So maybe check with them first. Also you could just insert a Cisco SFP You will likely need to reload for the device to recover though.
Let me know if that fixes it. I often use Finisar SFP, but still have problems with RJ45 GBIC. Fibre seems to be ok though.
