Highlighted
Beginner
Support with inter vlan routing (SGE 2000 small business series)
Hi!
  I'm not able to discover how it works properly the inter-vlan routing configuration.
So, an image is better than 1.000 words; I'm attaching to you a jpg with my problem.
By the way, the switch is isolated, while I'm doing the tests.
I think I've configured everything, but I'm only able to ping from PC1 to VLAN2 interface, and from PC2 to VLAN1 interface.
1 REPLY 1
Highlighted
Rising star
Hi Josep,
Is your sge2000 in layer 3 mode? Are the ports the pcs are connected to access or general? Latest firmware?
Are pc1 and pc2 set to enable ping echo requests? Check the ip routes and ensure that the two networks are showing up as local under route type.
Best,
David
Content for Community-Ad
