SVI vs no switchport
aksher
does both SVI, no switchport commands create same sense..i.e the first for intervlan communication and latter the same.
mahmoodmkl
Level 7
Level 7
SVI is created as a logical port than compared to using no switchport common under a physical interface.u can use both of them for intervlan routing depending upon u r topology.
In addition each SVI is associated with a seprate vlan.
Mahmood
Amit Singh
Aksher,
There is a difference the way both the connection works. Although they will have the same purpose but there is the difference the way the switch ports will work.
In case of a SVI you will have eventually a Layer-2 link between the switches. This will run your normal STP and other control traffic between the switches.This will extend your STP domain from a switch to the other switch.The ports will go thorugh the normal STP states and in case of a link flap or link going dowm/coming back the recovery time will be a little high.
In case of a routed port between the switches,you will have a layer 3 link between the switches and will work as a normal router port. There will no STP running on the ports and the STP domain will not be extended beyond the downstream switches.Applring layer3 features like ACL's,PBR's will be a ltille easy in this case.
The Disadvantage of running routed ports is that each port will be a separate network and you will have to manage a large number of IP subnets on the network. Running a routing protocol will be a good idea in this case.
My suggestion for running a point-point link between 2 layer3 device would always be a layer-3 link. But this also depends on the kind of network topology you have.
HTH, Please rate if it does.
-amit singh
