11-12-2008 02:05 PM 03-06-2019 02:27 AM 更新
I have two Chassis an 4506 and a 4507R (newer). I need more slots, so that why I am wanting to move the ethernet cards from one and vice versa. The cards in the 4507R are WS-x4516 supervisor engine V, and a WS-x4548-GB RJ45. The power supply in the 4507R are 2x1400. The blades in the 4506 chassis are WS-x4515, and WS-x4148-RJ. Will this work if I exchange the cards between the two chassis. Also I wasnt sure what the R in the 4507R stands for?
Jeff
解決済! 解決策の投稿を見る。
11-12-2008 02:11 PM
Jeff
The R means redundant in that the 4507R and 4510R support dual supervisors whereas the other 4500 chassis only support one supervisor.
If you swap the cards over bear in mind that it would help to make sure the cards go in the same slots in the other chassis - that way your config would still work.
Jon
11-12-2008 02:16 PM
Jeff,
This can be done quite easily. You will need to modify the interface configurations accordingly when you move the cards. The "R" stands for redundancy which allows you to have two supervisors running active/standby in the same chassis. Non "R" chassis will only accommodate one supervisor.
HTH,
Mark
P.S. You will need to run 12.1(19)EW or later on the 4506 to support the WS-x4548-GB RJ45 line card.
11-12-2008 02:18 PM
Jeff
The PoE will work but you need to make sure you have the correct power supplies to drive them.
Gigabit ports will work fine in either chassis.
Jon
11-12-2008 02:11 PM
Jeff
Jon
11-12-2008 02:13 PM
Thanks Jon for your quick response, I really appreciate it. The Eth blade on the 4507R are gig and Poe but not so for the 4506 do you think this would still work?
11-12-2008 02:18 PM
Jeff
Jon
11-12-2008 02:16 PM
Jeff,
HTH,
Mark
エキスパートの回答、ステップバイステップガイド、最新のトピックなどお気に入りのアイデアを見つけたら、あとで参照できるように保存しましょう。
コミュニティは初めてですか?これらのヒントを活用してスタートしましょう。 コミュニティの活用方法 新メンバーガイド
