03-05-2020 03:21 AM
Please kindly assist me on this, i cannot ping the switch but access and phones are working fine on it. I have been on this for the past 2 days without any result.
attached is the config file. Please help me check to know where am missing it.
THANKS.
03-05-2020 03:56 AM
Hi @Tosin Ola
Just to discard, you can verify that vlan 5 is created on the switch.
SVIs are not active until the associated vlan is created.
03-05-2020 03:58 AM
- Configure and connect the FastEthernet0 port , set IP address etc, you can connect to your switch using the ip address of the this management port.
M.
