Switch 2960X
fabio.nicolau1
When I turn on the 2960x the led syst is amber. Accessing the console gives the brom prompt. I type reset but do not reset the switch.
Help, please!
9 Replies 9
which prompt do you get, 'switch:' ?
brom>
The DRAM is toast. Contact Cisco TAC and organize RMA.
Leo Laohoo
Console into the switch and reboot.
Post the entire boot-up process. We want to see what is going wrong.
mohammed01701
Hi!
I think maybe the flash: is formatted. Can you post dir flash:? if the flash is empty then is likely that flash: is formatted? if is not try to boot the image that is on flash:
Can you also post output of command "set"?
/Mohammed
Hi!
Sorry, now i see that memory test is failed, This is  definitely hardware failure. I am afraid you have to replace it.
/Mohammed
Hi!
This switch is done and DEAD, do a RMA.
/Mohammed
