switch 2960xs system messages 2-critical Description: TCAM region 24 errormove failed, source index 4941 target index 4940.
quoc-truong
Dear sir
My cisco switch 2960xs run layer 3 warning error
How can fix this error ? I send for u file running-config on switch 2960xs 48POrt
Cisco suggests rebooting the switch. Have you rebooted it ?
TCAM region %d error: %s %d %s %d.
Explanation    TCAM manager region error.
Recommended Action    Reboot the switch.
http://www.cisco.com/c/en/us/td/docs/ios/system/messages/guide/sm_cn10.html
Masoud
Masoud
quoc-truong
Hello
Thanks. I was reboot my switch and correct fix error tcam
Glad your problem was solved.
Masoud
