Switch 3560G configuration help require
pannu3679
Hi All,
I'm configuring this switch for AVAYA PABX. At moment, I have configured 2 VLANs. VLAN1 is my voice VLAN and VLAN2 is my DATA VLAN. I have also configured IP routing for inter vlan communication. I am not sure how do I configure DHCP so that when my PC connect with AVAYA phone then it should get different IP address and AVAYA phone is going to directly connect with the switch and it should get different IP address.
Please find following switch config which I have done it so far....
INDOFFICESWI01#sh running-config
Building configuration...
Current configuration : 2654 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname INDOFFICESWI01
enable secret xxx
no aaa new-model
ip subnet-zero
ip routing
dot1x system-auth-control
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface GigabitEthernet0/1
switchport access vlan 2
switchport mode access
switchport voice vlan 1
mls qos trust dscp
interface GigabitEthernet0/2
mls qos trust dscp
interface GigabitEthernet0/3
mls qos trust dscp
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
interface GigabitEthernet0/25
interface GigabitEthernet0/26
interface GigabitEthernet0/27
interface GigabitEthernet0/28
interface GigabitEthernet0/29
interface GigabitEthernet0/30
interface GigabitEthernet0/31
interface GigabitEthernet0/32
interface GigabitEthernet0/33
interface GigabitEthernet0/34
interface GigabitEthernet0/35
interface GigabitEthernet0/36
interface GigabitEthernet0/37
interface GigabitEthernet0/38
interface GigabitEthernet0/39
interface GigabitEthernet0/40
interface GigabitEthernet0/41
interface GigabitEthernet0/42
interface GigabitEthernet0/43
interface GigabitEthernet0/44
interface GigabitEthernet0/45
interface GigabitEthernet0/46
interface GigabitEthernet0/47
interface GigabitEthernet0/48
interface GigabitEthernet0/49
interface GigabitEthernet0/50
interface GigabitEthernet0/51
interface GigabitEthernet0/52
interface Vlan1
description Voice VLAN
ip address 192.168.254.100 255.255.255.0
interface Vlan2
description Data VLAN
ip address 192.168.252.100 255.255.255.0
ip classless
ip http server
I've configured first 3 ports for testing purpose... You quick help will be much more appreciated...
Also, want to inform you that at present my PABX ip is in the range of 192.168.254.x. and that is the reason I have keep VLAN1 IP in this range.
Pans
6 Replies 6
chriswill
Try this config below
!Fisrt define a Dhcp pool
ip dhcp pool Data
network 192.168.252.0 255.255.255.0
default-router 192.168.252.100
ip dhcp pool Voice
network 192.168.254.0 255.255.255.0
default-router 192.168.254.100
! This makes sure that dhcp doesn't give the vlan address out to a host
ip dhcp excluded-address 192.168.254.100
ip dhcp excluded-address 192.168.252.100
You may want to change your trust on the ports to only trust the ip phone rather than any dscp value coming in from either phone or pc. Some applications are capable of putting in there own dscp values which may not be what you want.
Hope this helps
Chris
Hi Chris,
Thanks very much for your quick response.. I am going to connect my AVAYA phone to CISCO switch and PCs are going to connect with AVAYA phone..
I am planning write following command instead of mls qos trust dscp.
mls qos trust cos
Do I also need to write auto qos voip trust command ?
Your help will be much more appreciated...
THanks,
mls qos trust cos
THanks,
You will not need any mls commands on the interface.I would probably set up a class-map to match the voice traffic and then a policy-map to set the cos rating, then apply it to the vlan interface on the incoming side.
Example:
mls qos map cos-dscp 0 8 16 24 32 46 48 56
mls qos
access-list 1 permit 192.168.254.0 0.0.0.255
access-list 2 permit 192.168.252.0 0.0.0.255
class-map match-all Voice
match access-group 1
class-map match-all Data
match access-group 2
policy-map Phone_Data
class Voice
set ip dscp ef
class Data
set ip dscp af23
! On the interface that is the trunk port apply these commands
service-policy input Phone_Data
mls qos trust cos
Try that I think it should be ok
Chris
cjinfantino
Hey,
If I understand your question correctly you want to plug your phone into one of the switchports and have that get it's own IP address from vlan1 that you have setup, if that is the case you need to set up a new DHCP scope with the correct range of address that it should give out. Also one of the scope options needs to be the ip address of your vlan1 interface.
In addition, if your DHCP server is separated from this switch by a router or multi-layer switch you need to define the DHCP server's address as a helper address on that router or multi-layer switch. This will allow the phones DHCP request packet to be forwarded on to the DHCP server.
Lastly, it is 'best practice' to not use int vlan1 because the switches use that vlan to communicate cdp, stp, etc.
I hope this helps, if I have misunderstand your question I apologize.
hi,
No, you understood it perfectly. I have some requirement that is the reason I have used vlan1 for voice traffic.
