Switch 3750 Future Upgrade
bstemmler
We currently have 4 switches in a stack configuration shown below.
Switch             Product Description               Switch Software
Switch 1           WS-C3750G-24TS-S                          12.2(25) SEE-IP-SERV
Switch 2           WS-C3750G-24TS-S                          12.2(25) SEE-IP-SERV
Switch 3           WS-C3750-24TS-S                             12.2(25) SEE-IP-SERV
Switch 4           WS-C3750-24TS-S                             12.2(25) SEE-IP-SERV
All these switches have reached End of Life.  From End of Life document the replacement switches are:
Existing Switch                                   Replacement Switch
WS-C3750-24TS-S                             WS-C3750V2-24TS-S
WS-C3750G-24TS-S                          WS-C3750G-24TS-S1U
Can existing switches work with replacement switches?
If so does the software on existing need to be upgraded?
Antonio Knox
Level 7
Level 7
The switches will work together with no problem and you won't neeed any software upgrade unless there are specific features that you need that would require a different IOS image.
will.cullen
You may need to upgrade your IOS from 12.2(25), as I recently added a ws-c3750v2-48ts to an existing stack of ws-C3750-48ts and the original IOS version wouldn't run on the version 2 switch.
